1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Channel Archiver installation on Solaris 2.6
To: Wang Chunhong <[email protected]>
Cc: [email protected]
Date: Wed, 5 Jun 2002 16:21:15 -0400 (EDT)
On Tue, 4 Jun 2002, Wang Chunhong wrote:
> >  In file included from ../../../../../base/include/os/solaris/osiSock.h:36,
> >                   from ../HTMLPage.h:14,
> >                   from ../main.cpp:22,
> >                   from ../main.cc:6:
> >  /usr/include/net/if.h:86: `struct map' redeclared as different kind of
> >  symbol
> >  /usr/local/lib/gcc-lib/sparc-sun-solaris2.6/2.95.3/../../../../include/g++-
> > 3/stl_map.h:48: previous declaration of `template <class _Key, class _Tp,
> >  class _Compare = struct less<_Key>, class _Alloc = class allocator<_T2> >
> >  class
> >  map<_Key,_Tp,_Compare,_Alloc>'
I'm in the process of setting up ChannelArchiver here and ran into the
same problem. I'm using solaris 7 and gcc 2.95.3.
The clue is in EngineServer.cpp:
	#ifdef solaris
	// silly clash with struct map on Solaris
	// as long as namespaces are not used by egcs C++ library:
	#define _NET_IF_H
	#endif
Why this ifdef isn't working, I wasn't able to determine (solaris is
defined, and /usr/include/net/if.h begins with #ifndef _NET_IF_H). But I
was able to compile by explicitly not including <net/if.h>.
On a somewhat related note, MatlabExporter.cpp, GNUPlotExporter.cpp and
CGIInput.cpp do not compile when using the -ansi flag to gcc. Without it,
they compile fine.
Steve Hartman
[email protected] | 919-660-2650
Duke Free Electron Laser Laboratory
Re: Channel Archiver installation on Solaris 2.6 Wang Chunhong
Prev: Seq PV macros? Laznovsky, Michael
Next: Re: Help about caTcl guobao shen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Channel Archiver installation on Solaris 2.6 Wang Chunhong
Next: Re: Channel Archiver installation on Solaris 2.6 Wang Chunhong
