Hi, Steven
Thank you for your helpful messages. I also did so by explicitly not
including </net/if.h>. Engine compiled ok.
Thanks again!
Best regards,
Chunhong Wang
On Wed, 5 Jun 2002, Steven Hartman wrote:
> On Tue, 4 Jun 2002, Wang Chunhong wrote:
> > > In file included from ../../../../../base/include/os/solaris/osiSock.h:36,
> > > from ../HTMLPage.h:14,
> > > from ../main.cpp:22,
> > > from ../main.cc:6:
> > > /usr/include/net/if.h:86: `struct map' redeclared as different kind of
> > > symbol
> > > /usr/local/lib/gcc-lib/sparc-sun-solaris2.6/2.95.3/../../../../include/g++-
> > > 3/stl_map.h:48: previous declaration of `template <class _Key, class _Tp,
> > > class _Compare = struct less<_Key>, class _Alloc = class allocator<_T2> >
> > > class
> > > map<_Key,_Tp,_Compare,_Alloc>'
> I'm in the process of setting up ChannelArchiver here and ran into the
> same problem. I'm using solaris 7 and gcc 2.95.3.
> The clue is in EngineServer.cpp:
> #ifdef solaris
> // silly clash with struct map on Solaris
> // as long as namespaces are not used by egcs C++ library:
> #define _NET_IF_H
> #endif
> Why this ifdef isn't working, I wasn't able to determine (solaris is
> defined, and /usr/include/net/if.h begins with #ifndef _NET_IF_H). But I
> was able to compile by explicitly not including <net/if.h>.
> On a somewhat related note, MatlabExporter.cpp, GNUPlotExporter.cpp and
> CGIInput.cpp do not compile when using the -ansi flag to gcc. Without it,
> they compile fine.
- Re: Channel Archiver installation on Solaris 2.6 Steven Hartman
Re: Help about caTcl guobao shen
Real-time data correlator ready for beta test Peregrine M. McGehee
<2002>
2025
<2002>
2025
