1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re:buiding GDCT
To: Matthieu Bec <[email protected]>
Cc: <[email protected]>
Date: Wed, 24 Jul 2002 17:02:45 +0800 (CST)
Mr. Bec
thanks for your advice
I did it according to your method except that
I set $EPICS/base/lib/Linux-x86 to my LD_LIBRARY_PATH,
but it still shows the the same errors,I don't know what to do.
anyway,thank you!
best regards
On Tue, 23 Jul 2002, Matthieu Bec wrote:
> Hi Zhao Zhuo,
> check your base/config/CONFIG_SITE for:
> SHARED_LIBRARIES=YES
> append $EPICS/base/lib/Linux to your LD_LIBRARY_PATH, and rebuild base
> to create libDb.so
> from there, you should be able to proceed.
> cheers,
> Matthieu
> Zhao Zhuo wrote:
> > hello,everyone!
> > I've built base_R3_14_0.alhpa_2,now I want to build GDCT that is included
> > in extensions313_2.So I did the following:
> > cd extensions/src/gdct313
> > make
> > but it shows the following informations:
> > make -C tools buildInstall
> > make[1]: Entering directory `/home/zz/extensions/src/gdct313/tools'
> > make -C O.linux-x86 -f ../Makefile.Host T_A=linux-x86 BUILD_TYPE=Host
> > buildInstall
> > make[2]: Entering directory
> > `/home/zz/extensions/src/gdct313/tools/O.linux-x86'
> > g++    -O  -Wall   -D_X86_ -Dlinux   -DUNIX  -I. -I..
> > -I../../../../include -I../../../../include/os/Linux
> > -I../../../../../extensions/include -I../../../../../base/include
> > -I../../../../../base/include/os/Linux   -c   ../dbedit.cc
> > ..../dbedit.cc: In method `void menu::PrintList (long int (*) (DBENTRY
> > *), long int (*) (DBENTRY *), char *(*) (DBENTRY *))':
> > ..../dbedit.cc:206: warning: comparison between signed and unsigned
> > integer expressions
> > ..../dbedit.cc: In method `int menuMain::Command (char)':
> > ..../dbedit.cc:238: warning: suggest parentheses around assignment used
> > as truth value
> > ..../dbedit.cc: In function `int main (int, char **)':
> > ..../dbedit.cc:465: warning: unused variable `int j'
> > ..../dbedit.cc:465: warning: unused variable `int state'
> > ..../dbedit.cc:465: warning: unused variable `int i'
> > ..../dbedit.cc:465: warning: unused variable `int s'
> > ..../dbedit.cc:466: warning: unused variable `char *rname'
> > ..../dbedit.cc:466: warning: unused variable `char *pc'
> > ..../dbedit.cc: In function `char *ResolveName (char *)':
> > ..../dbedit.cc:543: warning: unused variable `int i'
> > g++ -o dbedit -O  -Wall   -D_X86_ -Dlinux   -DUNIX  -I. -I..
> > -L../../../../../base/lib/linux-x86/  -lpthread -lreadline -lcurses -lrt
> > dbedit.o    -lDb -lCom    -lm
> > /usr/bin/ld: cannot find -lDb
> > collect2: ld returned 1 exit status
> > make[2]: *** [dbedit] Error 1
> > make[2]: Leaving directory
> > make[1]: *** [buildInstall.linux-x86] Error 2
> > make[1]: Leaving directory `/home/zz/extensions/src/gdct313/tools'
> > make: *** [tools.buildInstall] Error 2
> > I don't know how to solve it,who can help me?
> > thanks in advance!
> > best regards!
Re: buiding GDCT Maren Purves
Re: Matthieu Bec
Prev: Re: Problem of ChannelArchive Thomas . Birke
Next: Re: ISEG VHQ204L Driver ahed aladwan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Matthieu Bec
Next: Re: buiding GDCT Maren Purves
