1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RTEMS dynamic loader SUCCESS
To: Till Straumann <[email protected]>, Glen Cornell <[email protected]>
Cc: [email protected], [email protected], wermelsk <[email protected]>, Harvey Rarback <[email protected]>
Date: Thu, 12 Sep 2002 06:58:08 -0500
Congratulations.
Till Straumann wrote:
> Today I had some good results :-)
> I could successfully load a major
> C++ application (EPICS example)
> into a running RTEMS system!
> Works like a charm.
> I recently ported my C-Expression interpreter
> and symbol table utility from libelf to BFD
> and it now features:
> - C expression interpreter with a simple type
>   engine (char, char*, int, int*, int(*)(), double...)
>   and access to symbols.
> - user variables (also typed - can be used to
>   define aliases etc.)
> - runtime loader; object modules can be loaded
>   to and unloaded from a running system
> - disassembler (comes free with BFD)
> Cexp/BFD is pretty portable, the full featured
> tool works not only on RTEMS but under several
> ELF platforms (linux-i386, linux-ppc, solaris-sparc).
> I suppose that the runtime loader needs some
> porting work when other BFD backends
> are used.
This is (to me) a hint that your dynamic loading solution shares
nothing with Glen Cornell's.  As I understand it, he used the
Xfree86 ELF dynamic loader to avoid problems with the GPL.
His solution is still stuck with the GPL for the disassembler
but that can be left out.
> C++ (exception) support is probably limited to gcc
> (and could unfortunately even be gcc-version sensitive)
That is good enough.
> Nevertheless, working with RTEMS begins to rock...
Yes.  I can't believe we went all these years with no
dynamic loading and now we have two solutions to look at
and merge.
> -- Till
> PS: Alas, I have to resolve annoying licensing issues
> before I can release this...
Maybe by merging the best of the two solutions, that would
be addressed.  I know Glen doesn't have a PowerPC to test on
anyway.  He has been working solely with the x86.
Regardless this is great news.  I just hope we can get the
two solutions merged into one superior one and merge the result.
Joel Sherrill, Ph.D.             Director of Research & Development
[email protected]                 On-Line Applications Research
Ask me about RTEMS: a free RTOS  Huntsville AL 35805
   Support Available             (256) 722-9985
RTEMS dynamic loader SUCCESS Till Straumann
Prev: RTEMS dynamic loader SUCCESS Till Straumann
Next: Re: e2db Rozelle Wright
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: EPICS Seminar at IHEP, Beijing Tadahiko Katoh
