1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VDCT groups
To: Geoff Savage <[email protected]>
Cc: EPICS tech-talk <[email protected]>, Luedeke Andreas <[email protected]>
Date: Tue, 03 Dec 2002 10:27:17 -0600
Geoff Savage wrote:
> Is it possible to generate template and generator files from VDCT?  We
> use both of these file types to populate our Oracle database from which
> we generate .db files.  I also find it handy to do development work with
> a template and generator file.
Yes. You can include $(SUBSITUTION) macros in VDCT fields. The latest
build includes hierarchies and gives the ability to pass macro values
into lower levels of the hierarchy.
A "generate database" command allows the hierarchical database to be
expanded into a flat database file. The syntax used to implement
hierarchies in VDCT will be incorporated into 3.15 so that hierarchies
can be expanded at load time should you desire.
John.
VDCT groups John Maclean
Re: VDCT groups Matthias Clausen
Re: VDCT groups Luedeke Andreas
Re: VDCT groups Geoff Savage
Prev: Re: VDCT groups John Maclean
Next: Re: VDCT groups Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VDCT groups Andrew Johnson
Next: Re: VDCT groups John Maclean
