1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Xwindow print from Linux
To: [email protected]
Date: Thu, 5 Dec 2002 15:46:03 -0600
I use the 'import' command from the ImageMagick suite of command line
graphics utilities.  If you use a command like
  import -colorspace GRAY -window root -frame pgm:- | lpr
then this tells import to grab the entire contents of the screen in grayscale
format and then write it to standard output in PGM format.  The ImageMagick
man page says that it can produce Postscript directly, but I don't actually
remember why I am using PGM output instead.  ImageMagick supports a very
long list of output formats.  If you know the X11 window id of the window
you want to print, you can specify that to the '-window' option instead of
'root'.  Alternately, you can leave out the '-window' option altogether
and 'import' will display a graphical cursor that you can use to select
the window you want to print.
Hope this helps.
Bill Lavender
On Thu, Dec 05, 2002 at 03:24:59PM -0600, Garrett D. Rinehart wrote:
> What do any of you use to get an x-window printed on a PS printer from Linux? I
> need something non-interactive that I can just call from my Tcl/tk script.
> On Solaris, the "xwd | xpr | lpr" worked great. My RedHat Linux 7.3 has xwd, but
> not xpr. For that matter, I've searched and searched and I cannot find any
> reference to xpr under Linux on the CDs or the web. Doesn't it exist? Is there
> something else that would do what I want?
Xwindow print from Linux Garrett D. Rinehart
Prev: Re: Xwindow print from Linux john sinclair
Next: Re: Xwindow print from Linux Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
