1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Xwindow print from Linux
To: "Garrett D. Rinehart" <[email protected]>
Cc: [email protected]
Date: Thu, 05 Dec 2002 16:49:28 -0500
>>> On 12/5/2002 at 15:24:59 CST, Garrett D Rinehart wrote:
  > What do any of you use to get an x-window printed on a PS printer from
  > Linux? I need something non-interactive that I can just call from my
  > Tcl/tk script.
  > On Solaris, the "xwd | xpr | lpr" worked great. My RedHat Linux 7.3 has
  > xwd, but not xpr. For that matter, I've searched and searched and I
  > cannot find any reference to xpr under Linux on the CDs or the
  > web. Doesn't it exist? Is there something else that would do what I
  > want?
I have successfully used "import", which is part of the ImageMagick
package.  It will do the grab and dump directly to PostScript (or many
other image formats).
Here's the command I used to make printing work from stripTool on Linux:
import -frame -window %d -page 581x752+20+20 -rotate '-90>' - | lp -d%s -o nobanner
The "-page" may not be needed. I think it was so the image would be scaled
properly to fit the page.  "-rotate" gets you landscape orientation.
The standard "xwd" doesn't handle 24-bit displays, so it probably
wouldn't work well even if you did have "xpr".
- brian
Aside to the developer(s) of stripTool:
  Please make the command used to grab and print configurable. Of all the
OSes I've used, only SunOS and Solaris have "xpr".
Xwindow print from Linux Garrett D. Rinehart
Prev: Re: Xwindow print from Linux Bill Lavender
Next: Fwd: Xwindow print from Linux Pete R Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
