1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building 3.14 on solaris Was: Building 3.13Extensions with 3.14 base Problem.
To: [email protected]
Date: Thu, 5 Dec 2002 12:25:23 -1000 (HST)
> Date: Thu, 05 Dec 2002 14:42:14 -0600
> From: Andrew Johnson <[email protected]>
> The easy answer is to set your LD_LIBRARY_PATH environment variable to a
[snip]
> Personally I think that on Linux at least we should be embedding the paths
> to the shared libraries into those binaries that use them.  I have this
> working, and will see if I can persuade Janet to accept it for R3.14.1
A little off the original topic, but for what it's worth, below is how to
avoid LD_LIBRARY_PATH in a solaris build of 3.14 (beta 2), in a fairly
generic environment.  (Note that GNU recommends using Solaris as and ld
with gcc/g++.)
First, make configuration file mods as shown below.  Note I am not doing
the vxworks builds for now.
$ cd /usr/local/epics/r3.14.0beta2/base/configure
$ diff CONFIG_SITE.original CONFIG_SITE
60,61c60
< #CROSS_COMPILER_TARGET_ARCHS=
< CROSS_COMPILER_TARGET_ARCHS=vxWorks-68040 vxWorks-ppc604
95c94
< SHARED_LIBRARIES=NO
> SHARED_LIBRARIES=YES
$ cd /usr/local/epics/r3.14.0beta2/base/configure/os
$ cat CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu
GNU_DIR = /usr/local
LD = /usr/ccs/bin/ld -r
DEPLIB_DIRS += /usr/local/lib /usr/local/epics/r3.14.0beta2/base/lib/solaris-sparc-gnu
SHRLIB_LDFLAGS_YES = -Wl,-G -Wl,-dy
SYS_SHRLIB_LIBS = posix4 pthread
Then, the procedure, simply:
setenv EPICS_HOST_ARCH solaris-sparc-gnu
gmake >& make.log
Note that the  SYS_SHRLIB_LIBS  redefinition was, if I recall correctly, to
remove the  Crun  from its definition in  CONFIG.Common.solaris-sparc .
The libCrun, however, might be needed to allow R3.13 build extentions to
load R3.14 shared libs, per a comment in that file.  Its inclusion, however,
broke my build on Solaris 8.  Perhaps the build has changed since then, as
this was in flux (e.g. changed from beta1).
Hope this helps.
Prev: Fwd: Xwindow print from Linux Pete R Jemian
Next: MEDM - alarm status not propagated for vis.calc Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
