1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Booting RTEMS IOC problem
To: [email protected]
Cc: [email protected]
Date: Fri, 13 Dec 2002 15:30:29 +0800
Thanks for replying...
My target PC has the Pentium III @ 866 CPU, base memory 640k,
extended memory 128M.
This is exactly what I got in my screen:
  Booting 'IOCtest'
kernel (hd0,0)/eb-5.0.8-rtl8139.lzlilo
  [Linux-zImage, setup=0x800, size=0xf600]
ROM segment 0x1000 length 0x4000 reloc 0x9400
Etherboot 5.0.8 (GPL) Tagged ELF for [RTL8139]
Boot from (N)etwork or from (L)ocal? N
Probing...[RTL8139]Found Realtek 8139 ROM address 0x0000
 - ioaddr 0XE800, addr 00:00:EC:D0:1F:C7 100Mbps half-duplex
Searching for server (BOOTP)...
..Me: 166.111.32.246, Server: 166.111.32.244
Loading 166.111.32.244:/epics/client1/bin/example.bt ...(NBI)... .
After "...(NBI)..." for 4-5 seconds, there is one more dot.
I do not have the following message printed:
......................done
A20 disabled via BIOS
What's more, I have already merged 16-bit startup code with my example,
following the steps on "Getting started with EPICS on RTEMS".
In your mail:
>From:Eric Norum <[email protected]>
>Reply-To:
>To: Till Straumann <[email protected]>
>On Thursday, December 12, 2002, at 01:40  PM, Till Straumann wrote:
>>> I believe that the 'NBI' means 'non-bootable image'.
>> My 2 cents:
>> Hmm - etherboot uses the term NBI also; there it means 'Net Boot Image'
>> which would indicate that it indeed could be the correct image (with
>> the startup stuff added).
>Hmm.
>As usual Till is correct -- I shouldn't have replied so hastily to the
>first message.
>In reply to that first message, how many dots are printed after the
>(NBI)?
>How much RAM does your target processor have?
>Do the bootstrap ROMs ever print the following?
>Department of Electrical Engineering
>University of Saskatchewan
>Saskatoon, Canada.
>Phone: (306) 966-5394   FAX:   (306) 966-5407
Prev: Re: Booting RTEMS IOC problem Eric Norum
Next: hi 黄松
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Booting RTEMS IOC problem Edwin
