1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Booting RTEMS IOC problem
To: "'Eric Norum'" <[email protected]>
Cc: <[email protected]>
Date: Sat, 14 Dec 2002 17:22:22 +0800
I have listened to my NIC, using tcpdump, through which I could find out
that
there are only 2k bytes translated via tftp udp port.
15:13:16.193469 166.111.32.246.2001 > tu032244.tsinghua.edu.cn.tftp:  51
RRQ "/epics/client1/bin/example.bt"
15:13:16.194699 tu032244.tsinghua.edu.cn.32887 > 166.111.32.246.2001:
udp 15 (DF)
15:13:16.194757 166.111.32.246.2001 > tu032244.tsinghua.edu.cn.32887:
udp 4
15:13:16.194843 tu032244.tsinghua.edu.cn.32887 > 166.111.32.246.2001:
udp 1436 (DF)
15:13:16.195150 166.111.32.246.2001 > tu032244.tsinghua.edu.cn.32887:
udp 4
15:13:16.195198 tu032244.tsinghua.edu.cn.32887 > 166.111.32.246.2001:
udp 1436 (DF)
I have tried hello.bt also, the result is the same.
I just chose my Ethernet card type as Realtek8139, and replaced BOOTP to
DHCP when configuring the rom-o-matic image, other setting is default.
BTW I have tried to boot 'example' with grub, the image does boot up,
following is the screen catch:(I have configured ne2000 net driver)
Initialized console on port CONSOLE
********** Initializing network *******
network device 'ne1' <FF:FF:FF:FF:FF:FF> initialized on port 0X300, irq
5
bootpc_init: using network interface 'ne1'
Bootpc testing starting
Bootpc hw address is ff:ff:ff:ff:ff:ff
BOOTP timeout for server 0xffffffff
seems it cannot find my bootpd server.
Thanks for replying...
Prev: Re: Building 3.13Extensions with 3.14 base Problem. Andrew Johnson
Next: Bug on Pentium IOC Bernd Schoeneburg
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Booting RTEMS IOC problem Edwin du
Next: hi 黄松
