1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: anyone using EPICS baseR3.14.1 on rtems target?
To: Eric Norum <[email protected]>
Cc: Tech-talk <[email protected]>
Date: Thu, 23 Jan 2003 13:05:43 -0800
M.C.Shao wrote:
> hi,all
> When I use baseR3.14.1 on i386-rtems target, I have serious problems.The
> following is the configuration of my building environment:
-- snip --
> make[3]: Entering directory
> `/usr/local/epics/exampleApp/testApp/src/O.RTEMS-pc386'
> /opt/rtems/bin/i386-rtems-g++ -B/opt/rtems/i386-rtems/pc386/lib/ -specs
> bsp_specs -qrtems   -o example
> -L/usr/local/epics/base/lib/RTEMS-pc386/    -u Init
> /opt/rtems/i386-rtems/pc386/lib/no-dpmem.rel
> /opt/rtems/i386-rtems/pc386/lib/no-mp.rel
> /opt/rtems/i386-rtems/pc386/lib/no-part.rel
> /opt/rtems/i386-rtems/pc386/lib/no-signal.rel
> /opt/rtems/i386-rtems/pc386/lib/no-rtmon.rel -Wl,-Ttext,0x100000
> xxxRecord.o devXxxSoft.o dbSubExample.o
> example_registerRecordDeviceDriver.o exampleMain.o    -lrecIoc
> -lsoftDevIoc -ltestDevIoc -liocsh -lmiscIoc -lrsrvIoc -ldbtoolsIoc
> -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom         -ltecla_r
> -lncurses -lm -lrtemsCom -lrtemscpu -lCom -lm
Unrelated to the original question: couldn't/shouldn't we remove the
ncurses dependency under RTEMS?
-- Till
Re: anyone using EPICS baseR3.14.1 on rtems target? Eric Norum
Prev: Re: jefferson lab ioc statistics Ralph Lange
Next: Re: anyone using EPICS baseR3.14.1 on rtems target? Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: jefferson lab ioc statistics Zoltan Kakucs
