1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: base R3.14.1 "example" application booting problem, and rdbg questions
To: "Tech-talk" <[email protected]>, "Eric Norum" <[email protected]>
Date: Fri, 24 Jan 2003 17:45:12 +0800
hello,all
Questions again.
I have update to EPICS baseR3.14.1 now. And build the "example" application for RTEMS-pc386 target.
After boot the "exmaple" application on my target machine, there are some errors delivered:
*****starting EPICS application*****
    assert failed: ../../../../../../../rtems-ss-20021118/cpukit/posix/src/types.c:40 0
EXECUTIVE SHUTDOWN!Any key to reboot...
Here are related contents in types.c:
38:    int POSIX_NOT_IMPLEMENTED()
39:    {
40:      assert( 0 );
41:      return 0;
42:    }
what does this mean? Where/when is this function called?
When I configure RTEMS, I have had the configuration option "--enable-posix" turned on.
And another questions, for I have realized that it's very necessary to install a rdbg environment,I installed gdb-5.2,patched with rtems patches.Then enabled rdbg in the "exmaple", after I issued command:
i386-rtems-gdb -b 38400 example
(gdb)target remote /dev/ttyS0
Remote debugging using /dev/ttyS0
This command will not return, if I type Ctrl+C after quite a while, it tells me that:
"Couldn't establish connection to remote target"
Meanwhile, on the target machine, REMOTE DBG initialized successfully, and are waiting connection all the time.
Have I forgot anything when I use this rdbg?
best regards,
Shao Mingchao
Engineering Physics Department
Tsinghua University
Beijing,100084,China
Re: base R3.14.1 "example" application booting problem, and rdbg questions Eric Norum
Prev: Re: jefferson lab ioc statistics Zoltan Kakucs
Next: Re: base R3.14.1 "example" application booting problem, and rdbg questions Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: anyone using EPICS baseR3.14.1 on rtems target? Eric Norum
