1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: R3.14.1 ioc example
To: tech-talk <[email protected]>
Date: Mon, 27 Jan 2003 16:53:15 -0600
I am trying to run the ioc example from the R3.14.1 AppDevGuide on a Redhat 8.0 machine.
I see no errors during the building of R3.14.1.
The commands I used to create the example app are the ones that
are shown in the AppDevGuide (the line continuation symbols are
only used here to keep the lines from becoming excessively long):
mkdir exampletop
cd exampletop
/net/snap-80gb/share1/epics/R3.14/base-3.14.1/bin/linux-x86/  \
	makeBaseApp.pl -t example example
	makeBaseApp.pl -i -t example example
The last line prompts me to choose an architecture.  I choose the
only one available (linux-x86).
I then issue a make and the build completes without error.
I can then attempt to run the ioc example:
cd /net/snap-80gb/share1/epics/R3.14/exampletop/iocBoot/iocexample
..../../bin/linux-x86/example st.cmd
and I get the following error message:
..../../bin/linux-x86/example: error while loading shared libraries: \
	libiocsh.so: cannot open shared object file: \
	No such file or directory
I have verified that EPICS_HOST_ARCH has been set correctly.
I have also built base and the example app with and without
$(INSTALL_LOCATION)/lib/$(EPICS_HOST_ARCH) added to
my LD_LIBRARY_PATH env. variable.
I have a feeling there is something small that I am overlooking.
Any suggestions would be greatly appreciated.
Kevin Peterson
Re: R3.14.1 ioc example Andrew Johnson
Re: R3.14.1 ioc example Till Straumann
Prev: Re: base R3.14.1 "example" application booting problem M.C.Shao
Next: Re: R3.14.1 ioc example Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: StripTool Nick Rees
