1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Darwin support for Objective-C and Foundation framework
To: [email protected]
Date: Mon, 10 Feb 2003 15:30:49 -0600
I've committed changes to support compilation of Objective C source files on Mac OS X. Applications can also use code from the Foundation framework.
To include an Objective-C source file in an application just add it to the source list in the application Makefile:
example_SRCS += exampleObjC.m
To link the Foundation framework into an application add the following as well:
example_LDFLAGS += -framework Foundation
Here's a short example showing how the Foundation framework can be used to send AppleScript messages to other applications:
 * exampleAppleScriptRecord.m
 * Simple Objective-C/AppleScript subroutine record
 * To use this record in an application:
 * 1) Make the following changes to the application Makefile:
 *    - Add exampleAppleScriptRecord.m to the application SRCS.
 *    - Add -framework Foundation to the application LDFLAGS.
 * 2) Add the following line to the application database description:
 *      function(exampleAppleScriptProcess)
 * 3) Add a record to the application database:
 *      record(sub,"setVolume")
 *          field(SNAM,"exampleAppleScriptProcess")
#import <Foundation/Foundation.h>
#include <subRecord.h>
#include <alarm.h>
#include <errlog.h>
#include <recGbl.h>
 * Shim between EPICS and NSAppleScript class.
long
exampleAppleScriptProcess(struct subRecord *psub)
    NSAutoreleasePool *pool = [[NSAutoreleasePool alloc] init];
    NSDictionary *err;
    NSAppleScript *nsa;
nsa = [[NSAppleScript alloc] initWithSource:[NSString stringWithFormat:
@"tell application \"Finder\" to set volume %g\n", psub->A]];
if ([nsa executeAndReturnError:&err] == nil) {
errlogPrintf("Failed to run AppleScript: %s\n",
[[err objectForKey:NSAppleScriptErrorMessage] cString]);
recGblSetSevr(psub, SOFT_ALARM, INVALID_ALARM);
[nsa release];
[pool release];
return 0;
Eric Norum                                 [email protected]
Advanced Photon Source                     Phone: (630) 252-2793
Argonne National Laboratory
Prev: Re: device support for R3.14.1 Linux IOC Andrew Johnson
Next: When must recGblResetAlarms be called? J. Frederick Bartlett
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
