1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: When must recGblResetAlarms be called?
To: tech-talk <[email protected]>
Cc: bartlett <[email protected]>
Date: Mon, 10 Feb 2003 15:40:02 -0600
  I have a question concerning the use of the function recGblResetAlarms in
conjunction with the db_post_events function.
  I wish to raise a monitor event when selected fields of a record are
changed by a dbPutField call (usually via a channel access message).  The
fields are all marked for special processing -- the special(SPC_MOD)
attribute of the field has been set. The examples indicate that monitor
activation during the "process" phase clearly require an initial call to
recGblResetAlarms; however, when the change of value takes place outside of
a call to the record's process function, does recGblResetAlarms need to be
invoked?
									Fritz
Re: When must recGblResetAlarms be called? Marty Kraimer
Prev: Darwin support for Objective-C and Foundation framework Eric Norum
Next: Re: When must recGblResetAlarms be called? Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
