1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: When must recGblResetAlarms be called?
To: "J. Frederick Bartlett" <[email protected]>
Date: Tue, 11 Feb 2003 08:00:32 -0600
J. Frederick Bartlett wrote:
  I have a question concerning the use of the function recGblResetAlarms in
conjunction with the db_post_events function.
  I wish to raise a monitor event when selected fields of a record are
changed by a dbPutField call (usually via a channel access message).  The
fields are all marked for special processing -- the special(SPC_MOD)
attribute of the field has been set. The examples indicate that monitor
activation during the "process" phase clearly require an initial call to
recGblResetAlarms; however, when the change of value takes place outside of
a call to the record's process function, does recGblResetAlarms need to be
invoked?
Fritz
In most cases recGblResetAlarms should NOT be called.
Let's review what recGblResetAlarms does (It also sets alarm mask but that is not important for this discussion).
It sets
stat = nsta    set status equal to new status
sevr = nsev    set severity equal to new severity
nsta = 0       set new status to 0
nsev = 0       set new severity to 0
What is assummed is that no more alarms will be raised from the time recGblResetAlarms is called until db_post_event is called for any field that the record support process method monitors. recGblSetSevr changes the nsta and nsev fields NOT the stat and sevr fields. If something not connected with processing calls recGblResetAlarms then alarms connected with record processing may be lost.
Fritz's question relates to issuing a db_post_event to a field that is not monitored by the record support module. The status and severity that will be associated with the db_post_event will be the status and severity related to the last time recGblResetAlarms was called, i.e. the last time the record was processed.
In most cases this should be OK. If the db_post_event is for a field not monitored when the record is processed alarms should not be of interest. For example consider the aiRecord. It has a special routine that looks for field LINR being changed. If it detects a change it also checks to see if ESLO and EOFF change and if they change it calls db_post_event. If a CA client monitors these fields asking for severity and status it will get the status and severity from the last time the record was processed. Thus it could get the old status and severity even though they have changed because the record has started but not completed processing. I will maintain that the CA client should not be asking for status and severity for such fields. If it does it will also receive an event each time the status and severity change.
If a record support module has a lot more "state" than normal records perhaps there might be a reason for code other than process to call recGblResetAlarms. But think hard before creating such record support.
Marty Kraimer
RE: When must recGblResetAlarms be called? J. Frederick Bartlett
Prev: When must recGblResetAlarms be called? J. Frederick Bartlett
Next: RE: When must recGblResetAlarms be called? J. Frederick Bartlett
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
