1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: HOST:WIN32 with IOC:Linux: is there environment variables in HOST?
To: LANGLOIS Florent <[email protected]>
Cc: "Ernest L. Williams Jr." <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Fri, 21 Feb 2003 13:36:55 +0100
  > Indeed, there are Env variables that need to be set on your WIN32
  > platform.  The two main env vaiables for channel access clients for
  > EPICS 3.14:
  > By the way the same env variables must be set on any host including
  > LINUX.
  > For more info about CA env variables see:
  > http://www.aps.anl.gov/epics/modules/base/R3-14/1-docs/CAref.html
Looking in the docs is definitely worth giving a try, but generally
all these environment variables have reasonable default values, so you
only _have_ to set them if your system is configured in a non-standard
way.
Other things to look for include:
 - Check the network connection of your windows box: Is the IP number in
   the right network? Does the network mask match? Can you ping the IOC
   system from the windows command line?
 - If your windows box and the IOC are not in the same IP subnet: Read
   the appropriate chapter of the Channel Accesss doc. In this case you
   _will_ have to set variables on the client system to make things work.
 - Check the environment on your working linux client system: if any
   variables related to CA are set, try setting them accordingly on the
   windows box.
 - Check the environment of your linux IOC system: are any CA-related
   variables set which change the behaviour of the IOC? You will have to
   use the matching settings on the client system.
 - Check if your linux IOC has Access Security enabled. If so, the
   Access Security file might have to be changed to allow access from
   your windows box.
All Channel Access environment variables are described in the doc that
Ernest pointed you to.
Access Security is documented in the Application Developer's Guide.
First of all: Good luck!
Ralph
HOST : WIN32 with IOC:Linux: is there environment variables in HOST? LANGLOIS Florent
Re: HOST : WIN32 with IOC:Linux: is there environment variables in HOST? Ernest L. Williams Jr.
Prev: Re: HOST : WIN32 with IOC:Linux: is there environment variables in HOST? Ernest L. Williams Jr.
Next: RE: HOST:WIN32 with IOC:Linux: is there environment variables in HOST? LANGLOIS Florent
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
