Indeed, there are Env variables that need to be set on your WIN32
platform. The two main env vaiables for channel access clients for
EPICS 3.14:
Search the local subnet for the PV of your choice
Must be set to either YES or NO
EPICS_CA_AUTO_ADDR_LIST=<YES/NO>
Search specific CA servers in a certain order
EPICS_CA_ADDR_LIST=<A list of CA server IP addresses>
example, given that my linux-x86 IOC's IP number is 172.20.72.67, then
EPICS_CA_ADDR_LIST=172.20.72.67
When using large arrays in 3.14 max array size in bytes
EPICS_CA_MAX_ARRAY_BYTES=<max array size in bytes>
By the way the same env variables must be set on any host including
LINUX.
For more info about CA env variables see:
http://www.aps.anl.gov/epics/modules/base/R3-14/1-docs/CAref.html
Ernest L. Williams JR.
SNS Control Systems Group
ORNL
On Fri, 2003-02-21 at 06:04, LANGLOIS Florent wrote:
> hi everyone,
> i have a WIN32 channel access client and an IOC running on a linux x86 .
> i want to read/write PVs/records from my client to the ioc
> but it doesn't work
> however, when i use a channel access client on the ioc linux platform, it works!
> so is there an env variable or something so that i can read the records from the network in my WIN32 platorm?
> im not sur if i have been clear, but i hope you could answer me!
> thank you
> Florent Langlois
> Division Informatique
> Synchrotron SOLEIL
> L'Orme des Merisiers
> St-Aubin - BP 48
> 91192 GIF-sur-YVETTE
> TÃl : 01.69.35.93.31
> [email protected]
> www.synchrotron-soleil.fr
- Re: HOST:WIN32 with IOC:Linux: is there environment variables in HOST? Ralph Lange
- HOST : WIN32 with IOC:Linux: is there environment variables in HOST? LANGLOIS Florent
<2003>
2025
<2003>
2025
