1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Long expressions using MAX and MIN in CALC fields
To: "'Andrew Johnson'" <[email protected]>
Cc: "Tech-Talk (E-mail)" <[email protected]>
Date: Wed, 26 Feb 2003 17:01:05 -0800
Actually, Andrew, changing the parser to use infix notation was trivial, as
my original message indicated.  The only change needed is that two-line
addition to the table of operators.  I have tested this and verified that it
works.  If there is a pseudo-standard (g++) that uses ">?" and "<?" for the
infix MAX and MIN operators, then I will cheerfully switch to that.
I think it would be hard to modify the parser to recognise variable numbers
of arguments.  I much prefer this notation, but I really do not see an easy
way to do it.
I am using genSubRecords in other places, but they have overhead of their
own and are not as easily understood or debugged as a calcoutRecord.  The
calcoutRecord does EXACTLY what I want, except that the CALC field was too
small for the expression in its original form.
Thanks for the thoughts!
Dr. Russell O. Redman
Tel: (250) 363-6917 | Fax: (250) 363-0045
<mailto:[email protected]>
National Research Council Canada | Conseil national de recherches Canada
5071 West Saanich Road           | 5071 West Saanich Road
Victoria, B. C. V9E 2E7          | Victoria, C.-B. V9E 2E7
Government of Canada             | Gouvernement du Canada
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Wednesday, 2003 February 26 4:48 PM
> To: Redman, Russell O.
> Cc: Tech-Talk (E-mail)
> Subject: Re: Long expressions using MAX and MIN in CALC fields
> Redman, Russell O. wrote:
> > I would like to suggest a small enhancement for the calcRecord,
> > calcoutRecord and waitRecord code that uses the postfix
> routine.  This
> > enhancement will allow the MAX and MIN operators to be used
> on many more
> > input fields than is currently possible due to the limited number of
> > characters permitted in the CALC fields of these records.
> I like the idea that MAX and MIN should be able to take
> variable numbers
> of arguments, using this syntax:
> >   MAX(A,B,C,D,E,F,G,H,I)
> However I'm not sure how easy this would be to add to the parser.
> > I know I can do the calculation with a select record
> > and a calcout, but these records are used in a time
> sensitive part of my
> > database and the calculation is nested quite deeply.  If at
> all possible, I
> > would like to complete the operation using a single calcout record.
> I would have thought that a subroutine record would be significantly
> faster than using a calc for this - admitedly it's not going
> to be quite
> as flexible at runtime, but a lot less work in the short term than
> changing the calculation engine and parser.
> If you need the output capability of calcout, you might want
> to look at
> Andy Foster's genSub record which is an enhanced subroutine
> record that
> provides output links.
> > Unfortunately, most of the obvious punctuation characters have
> > already been used for other operations, but I suggest that
> "|<" and ">|"
> > might be suitable as binary MIN and MAX operators, respectively.
> The GNU C++ compiler has a built-in extension for MIN and MAX
> that uses <?
> and >? respectively as the binary operators.  Although I'd
> prefer that we
> stick as close as possiblt to the standard C operators and function
> syntax, if a variable-length MIN() and MAX() can't easily be
> developed
> it's probably better to regard g++ as a sort of standard and
> re-use their
> operators.
> - Andrew
> Tongue-twister: Say "Peggy Babcock" 10 times without stumbling...
Prev: Re: Long expressions using MAX and MIN in CALC fields Andrew Johnson
Next: Re: Long expressions using MAX and MIN in CALC fields Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Long expressions using MAX and MIN in CALC fields Tim Mooney
Next: RE: Long expressions using MAX and MIN in CALC fields Redman, Russell O.
