1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Long expressions using MAX and MIN in CALC fields
To: "Redman, Russell O." <[email protected]>
Cc: "Tech-Talk (E-mail)" <[email protected]>
Date: Wed, 26 Feb 2003 18:47:43 -0600
Redman, Russell O. wrote:
I would like to suggest a small enhancement for the calcRecord,
calcoutRecord and waitRecord code that uses the postfix routine.  This
enhancement will allow the MAX and MIN operators to be used on many more
input fields than is currently possible due to the limited number of
characters permitted in the CALC fields of these records.
I like the idea that MAX and MIN should be able to take variable numbers of arguments, using this syntax:
MAX(A,B,C,D,E,F,G,H,I)
However I'm not sure how easy this would be to add to the parser.
I know I can do the calculation with a select record
and a calcout, but these records are used in a time sensitive part of my
database and the calculation is nested quite deeply.  If at all possible, I
would like to complete the operation using a single calcout record.
I would have thought that a subroutine record would be significantly faster than using a calc for this - admitedly it's not going to be quite as flexible at runtime, but a lot less work in the short term than changing the calculation engine and parser.
If you need the output capability of calcout, you might want to look at Andy Foster's genSub record which is an enhanced subroutine record that provides output links.
Unfortunately, most of the obvious punctuation characters have
already been used for other operations, but I suggest that "|<" and ">|"
might be suitable as binary MIN and MAX operators, respectively.
The GNU C++ compiler has a built-in extension for MIN and MAX that uses <? and >? respectively as the binary operators. Although I'd prefer that we stick as close as possiblt to the standard C operators and function syntax, if a variable-length MIN() and MAX() can't easily be developed it's probably better to regard g++ as a sort of standard and re-use their operators.
- Andrew
Tongue-twister: Say "Peggy Babcock" 10 times without stumbling...
Re: Long expressions using MAX and MIN in CALC fields Tim Mooney
Long expressions using MAX and MIN in CALC fields Redman, Russell O.
Prev: Long expressions using MAX and MIN in CALC fields Redman, Russell O.
Next: RE: Long expressions using MAX and MIN in CALC fields Redman, Russell O.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Long expressions using MAX and MIN in CALC fields Tim Mooney
