1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Long expressions using MAX and MIN in CALC fields
Cc: "Redman, Russell O." <[email protected]>, "Tech-Talk (E-mail)" <[email protected]>
Date: Thu, 27 Feb 2003 13:48:56 -0600
Andrew, re...,
> The GNU C++ compiler has a built-in extension for MIN and MAX that uses <?
> and >? respectively as the binary operators.  Although I'd prefer that we
> stick as close as possiblt to the standard C operators and function
> syntax, if a variable-length MIN() and MAX() can't easily be developed
> it's probably better to regard g++ as a sort of standard and re-use their
> operators.
I think <? would be valuable even if min(a,b,c,d,...) existed, because in some
cases using the operator would yield a clearer expression.  But I certainly
agree that sticking to standards is the way to go.  Otherwise we might get more
functions like "loge" (should be "ln"), and operators like "#" (should be "!="
or "<>").
To this end, does anyone happen to know the precedence and associativity of these
operators?  I.e.,
does  a + b <? c   mean  (a + b) <? c   or  a + (b <? c)
does  a <? b <? c  mean  (a <? b) <? c  or  a <? (b <? c)
does  a * b <? c   mean  (a * b) <? c   or  a * (b <? c)
etc.  I haven't been able to find this information online.
Tim Mooney ([email protected]; 630-252-5417)
Advanced Photon Source
APS Operations Division
Beamline Controls & Data Acquisition Group
Re: Long expressions using MAX and MIN in CALC fields Noboru Yamamoto
Re: Long expressions using MAX and MIN in CALC fields Andrew Johnson
Long expressions using MAX and MIN in CALC fields Redman, Russell O.
Prev: RE: Long expressions using MAX and MIN in CALC fields Redman, Russell O.
Next: Re: Long expressions using MAX and MIN in CALC fields Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Long expressions using MAX and MIN in CALC fields Andrew Johnson
Next: Re: Long expressions using MAX and MIN in CALC fields Noboru Yamamoto
