1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: initialize of mbbi state labels
To: [email protected]
Date: Mon, 03 Mar 2003 15:29:32 -0500
EPICS philosophical question of the day........
	Suppose there is a piece of equipment which can be put into
one of several modes of operation. Suppose also that the set of possible
modes depends on the hardware configuration of the equipment. Suppose
finally that the set of possible modes can be queried programmatically.
	What is the "best" way to populate the "ZRST", "ONST", ...
fields of the record?
	Query the device during the "record init" phase, and
programmatically fill in the fields?
	Edit the .db file to conform to the known H/W configuration,
and re-edit as needed if the H/W changes?
Other?
What are pros and cons of various approaches.
	One example of such H/W are certain frame grabbers which have
H/W image processing built onto daughter cards. There are different
sets of image processing algorithms available with different daughter
cards attached.
	Another example is a transient recorder with options for
stored waveform length, which are ultimately constrained by the amount
of memory installed.
-- Larry
Re: initialize of mbbi state labels Bob Dalesio
Prev: Re: Any modern solution besides the TVs and EPICS alarm handler ? Kate Feng
Next: Re: initialize of mbbi state labels Bob Dalesio
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Job Opening Ned D. Arnold
