1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: initialize of mbbi state labels
To: "Hoff, Lawrence" <[email protected]>, [email protected]
Date: Mon, 03 Mar 2003 13:35:23 -0700
I would put it into the device support initialization area -
It can be done at initiallization.
Device support has a pointer to the record - so it's able to write directly into the fields ZNAM, ONAM, etc....
At initialization, there should be no channel access clients connected that could request these strings before they are initialized.
A problem would be if the assignment of these values can change. Channel access clients monitor the value as a short and only send the string assignments at connection time. So that is a possible problem. If they can change - you may want to map them from a static assigment to the dynamic values in the device support only - and not export the fact that the strings are assigned different values at different times.
On Mon, 03 Mar 2003 15:29:32 -0500 "Hoff, Lawrence" <[email protected]> wrote:
EPICS philosophical question of the day........
Suppose there is a piece of equipment which can be put into
one of several modes of operation. Suppose also that the set of possible
modes depends on the hardware configuration of the equipment. Suppose
finally that the set of possible modes can be queried programmatically.
What is the "best" way to populate the "ZRST", "ONST", ...
fields of the record?
	Query the device during the "record init" phase, and
programmatically fill in the fields?
Edit the .db file to conform to the known H/W configuration,
and re-edit as needed if the H/W changes?
Other?
What are pros and cons of various approaches.
One example of such H/W are certain frame grabbers which have
H/W image processing built onto daughter cards. There are different
sets of image processing algorithms available with different daughter
cards attached.
Another example is a transient recorder with options for
stored waveform length, which are ultimately constrained by the amount
of memory installed.
-- Larry
Bob Dalesio [email protected] 410 557 0297 Maryland 505 667 3414 Los Alamos 505 699 1632 Cell Phone 505 667 6087 Our Secretary (Lisa Marie)
Re: initialize of mbbi state labels Hoff, Lawrence
Prev: initialize of mbbi state labels Hoff, Lawrence
Next: RE: initialize of mbbi state labels Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: initialize of mbbi state labels Hoff, Lawrence
