1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: initialize of mbbi state labels
To: "Hoff, Lawrence" <[email protected]>, <[email protected]>
Date: Mon, 3 Mar 2003 14:48:01 -0600
> 	Suppose there is a piece of equipment which can be put into
> one of several modes of operation. Suppose also that the set
> of possible modes depends on the hardware configuration of the equipment. Suppose
> finally that the set of possible modes can be queried
> programmatically.
> 	What is the "best" way to populate the "ZRST", "ONST", ...
> fields of the record?
> 	Query the device during the "record init" phase, and
> programmatically fill in the fields?
This is what I do, and I think it makes the most sense, since the software auto adapts to the hardware, as long as the IOC is rebooted after the hardware is reconfigured.
However, I would like to take this one step further.  I have some hardware which can be configured by EPICS software, but changing the configuration requires a change in the names of the ZRST, ONST, etc. files.  For example, I can change the "shaping time range" of an amplifier.  If it is in range 1, then there is a menu of available shaping times which should read "0.1 microsecond", "0.2 microsecond", etc.  However, if I change to range 2, then the menu should read "1.0 microsecond", "2.0 microsecond".  My device support software currently makes these required changes in the ZRST, ONST, etc. fields.
Here is the problem:  I have not found a way to get medm to redraw these menus when they change.  If I close the medm window and reopen it, then the new menu choices are correctly displayed.  Is there a way to post a monitor on an enum field so that CA clients will know that the values of the enum strings themselves have changed?
Mark Rivers
Re: initialize of mbbi state labels Benjamin Franksen
Prev: Re: initialize of mbbi state labels Bob Dalesio
Next: Re: initialize of mbbi state labels Hoff, Lawrence
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: initialize of mbbi state labels Hoff, Lawrence
Next: Re: initialize of mbbi state labels Benjamin Franksen
