1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: medm unable to contact CA repeater after 50 tries
To: "Jeff Hill" <[email protected]>
Cc: "Tech-talk" <[email protected]>
Date: Fri, 28 Mar 2003 11:56:57 +0800
hi, Jeff, medm is built with that 2003-03-12 base cvs snapshot. And there is no such kind of problems using caEventRate <PV>.
I find what result in this problem. When I build medm with baseR3.14.0beta2 and baseR3.14.1, there will be no this problem.
So I think it's the base3.14 cvs snapshot 2003-03-12 that causes this problem. But unfortunately, when I use the last two base3.14 cvs snapshots(20030323 and 20030326), they cann't be compiled or run correctly, respectively. (By the way, my target architecture is i386-rtems. ) So I'm not sure whether you've fixed this unknown reason which are causing this medm problem untill now. I make sure that it is NOT my configuration or settings in base3.14-cvs-snapshot-20030312 which result in this medm problem.
    And it seems to me that there are another serious problem in all current version of baseR3.14*  when using i386-rtems. To be more clear, I will describe this problem in another seperate email.
regards,
Shao Ming-chao
----- Original Message -----
> Is your MEDM compiled and linked with this 2003-03-12 base
> snapshot? Do you see this problem when the "caEventRate <PV
> name>" is run from the 2003-03-12 base snapshot?
> Jeff
RE: medm unable to contact CA repeater after 50 tries Jeff Hill
Prev: "assert (!plink->value.pv_link.pvt)" failed Feng, Shuchen
Next: ca client cannot connect server M.C.Shao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: medm unable to contact CA repeater after 50 tries Jeff Hill
Next: problem with SNC/SEQ Version 1.9.2.Beta12 Oleg Makarov
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
