I began to investigate 3.14.1 in our environment. I have no problems building and running this release for solaris-sparc, but I've got some mad errors compiling the same release for MVME5100 PowerPC. The compiler is the supplied cross-compiler of the Tornado2.2 installation package. This is the error I'm getting: /u1/wind/2.2_PowerPC/host/sun4-solaris2/bin/ccppc -c -D_POSIX_SOURCE -DCPU=PPC604 -DvxWorks -include /u1/wind/2.2_PowerPC/target/h/vxWorks.h -ansi -pedantic -O3 -Wall -mcpu=604 -mstrict-align -fno-implicit-templates -fno-builtin -I. -I.. -I../../../include/os/vxWorks -I../../../include -I/u1/wind/2.2_PowerPC/target/h ../cac.cpp In file included from /u1/wind/2.2_PowerPC/target/h/vxWorks.h:182, from ../cac.cpp:1: /u1/wind/2.2_PowerPC/target/h/types/vxTypes.h:112: warning: ANSI C++ does not support `long long' /u1/wind/2.2_PowerPC/target/h/types/vxTypes.h:117: warning: ANSI C++ does not support `long long' In file included from /u1/wind/2.2_PowerPC/target/h/vxWorks.h:183, from ../cac.cpp:1: /u1/wind/2.2_PowerPC/target/h/types/vxTypesOld.h:87: warning: ANSI C++ does not support `long long' /u1/wind/2.2_PowerPC/target/h/types/vxTypesOld.h:92: warning: ANSI C++ does not support `long long' In file included from ../virtualCircuit.h:35, from ../cac.cpp:37: ../comQueSend.h: In method `void comQueSend::push<ca_uint16_t>(const ca_uint16_t &)': .../comQueSend.h:145: instantiated from here .../comQueSend.h:123: Internal compiler error. .../comQueSend.h:123: Internal compiler error: .../comQueSend.h:123: Please submit a full bug report. gmake[3]: *** [cac.o] Error 1 gmake[3]: Leaving directory `/import/epicsf2/user/group/mks/kakucs/EpicsR3.14.1/base/src/ca/O.vxWorks-ppc604' gmake[2]: *** [install.vxWorks-ppc604] Error 2 gmake[2]: Leaving directory `/import/epicsf2/user/group/mks/kakucs/EpicsR3.14.1/base/src/ca' gmake[1]: *** [ca.install] Error 2 gmake[1]: Leaving directory `/import/epicsf2/user/group/mks/kakucs/EpicsR3.14.1/base/src' gmake: *** [src.install] Error 2 I am about to investigate this problem, but currently I have no bright idea how to solve this. Has anyone else seen this problem ? Regards Zoltan Kakucs
ANJ, 10 Aug 2010 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
