Marty Kraimer wrote :
>I am not familiar with the Joerger VSC16 device support so it is hard to
>know where to start.
>The error is because some DBF_XXXLINK has not been initialized properly.
>Some suggestions.
>If you know how to use a linux source level debugger it will make your
>task easier.
>If not do the following:
>Put printf statement in the init_record routines of both record and
>device
>support. Put the printf statement at entrace and exit and before/after
>any call
>to other routines.
>Then send another Email message showing.
>1) The output of the printfs
>2) The source for the device support.
>3) If any recordtype not coming from base is used, it's source.
>3) The record definitions from the database that causes the problem.
It turns out that cascaded problems pointed the blame at EPICS sources.
At this moment, I found no evidence against the EPICS source yet after
I tracked down the root cause of the error message. The root cause
has to do with the internal EPICS setup on my computer.
Kate
Re: "assert (!plink->value.pv_link.pvt)" failed Marty Kraimer
Building 3.14.1 for MVME5100 (Internal compiler error) Zoltan Kakucs
<2003>
ca client cannot connect server M.C.Shao
<2003>
