1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: NI1014 GPIB controller
To: "Marty Kraimer" <[email protected]>, <[email protected]>
Date: Mon, 14 Apr 2003 21:13:32 -0500
Marty wrote:
> If programed transfers are used instead of DMA there are two big advantages.
> 1) A24 DMA is no longer required. Thus it will no longer be necessary
> to modify the board support packages in order to support the NI1014.
I'm not quite sure I understand what you mean by this.  Are you suggesting eliminating support for A24 DMA entirely in the BSP, or just for some quirk of the NI1014?  We use the Kinetic Systems 2917 VME/CAMAC adapter, which uses A24 DMA.  We definitely need to be able to continue to use these, there are a dozen or more in use on beamlines where they control a critical CAMAC device for multi-element fluorescence detectors.
Mark Rivers
Re: NI1014 GPIB controller Marty Kraimer
Prev: RE: drvAscii R3.14 version Kevin Tsubota
Next: RE: recDynLink.c for R3.14.1 ? Feng, Shuchen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: NI1014 GPIB controller Marty Kraimer
Next: Re: NI1014 GPIB controller Marty Kraimer
