1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: recDynLink.c for R3.14.1 ?
To: [email protected]
Date: Tue, 15 Apr 2003 10:41:06 -0400
Hi Tim,
Tim Mooney wrote:
> -- snip --
> > Did you mean not to process the next link untill the triggering link
> > completes ? I thought I could get this done in the R3.13 using the
> > FLNK options, which perhaps called the original recDynLink.c or others.
> > Maybe I misunderstand what you meant for the putNotify callback.
> You can get pretty far in this direction with FLNK's, but that's not what
> the seq record does.  It just does db or ca puts to its output links, and
> fires those links on a schedule. It doesn't know or care whether processing
> started by a link is finished before it fires the next link.
> The FLNK-based solution doesn't wait for completion of work started by a CA
> link, so it's restricted to a single ioc.
> > However, Bob Dalesio wrote earlier :
> > > If all this record allows is the ability to change address links
> > > dynamically, it is no longer needed. Since 3.13, all address fields can
> > > be changed dynamically. I do not recall what else that it did.
> > It tells me that the capability of the dynamic link is not done
> > in the file recDynLink.c. Can someone please tell me what files
> > implement the dynamic link in R3.14 ? Where is the up-to-date
> > document for using the dynamic link in R3.14 (even R3.13) ?
> Marty and Bob, and maybe others, wrote the EPICS dynamic links, and those
> links don't use recDynLink.  recDynLink still exists only because there is
> no other convenient way for a database to do a ca_put_callback.  (Note that
> this is not a capability solely of the link; the record must also have a
> callback routine, and its process() routine must know what to do when that
> callback comes in.  Also, the record must handle the possibility that an
> expected callback will not come in, that ca_put_callback () might fail
> because another ca_put_callback is already in progress, etc.)
> > Tim wrote :
> > >Note that the version of recDynLink in base has never had this
> > >capability, so if you've been using the version from base, you
> > >can switch to standard links.  We still need recDynLink for the sscan
> > >and
> > >swait records, because they must wait for processing they start to
> > >finish,
> > Tracing tech-talk, I got the impression that the
> > swait and wait records should be replaced by sCalcout and Calcout
> > records, which seems to be true for my motor test so far.  However,
> > I am new to the stdApp and motor application.  The sscan record is
> > what I am pondering for its (motor) application of the dynamic link.
> Here's my understanding of all the EPICS calculation records:
> wait      -- retired, replaced by calcout
> calcout   -- use for calculations unless you have a specific reason to use
>              something else
> swait     -- use only if you need a ca_put_callback link
> sCalcout  -- use only if you need string expressions--for example, to
>              program dynamic links, or to talk to a serial device.
> transform -- use only if you need to evaluate several expressions, or
>              a very complicated expression, or if you need multiple
>              inputs/outputs.
> The sscan record is altogether different from any of calculation record.
> It's job is to make a change, wait for the change to complete, make a
> measurement, wait for the measurement to complete, and loop.
> > Tim wrote:
> > >and I plan to write a version of the seq record with the option of
> > >waiting
> > >until processing started by one link has finished before firing the next
> > >link
> > >in the sequence.  We've been doing this with sequences of swait records
> > >often
> > >enough to know that the capability will get used.
> > Hmm.  I thought this was done in EPICS already.
> > However, I have to admit that I never used seq record yet for my
> > application.
> No.  To my knowledge, nothing available to an EPICS database programmer
> ensures in every case that processing started by link A will finish before
> link B fires, except a callback link.
The issu is really to do a ca_put_callback.  In the past, I used other ways  of
programming to get around that for simpler applications.    However,  you had
your reason to write the scaler and motor records in a fashion that you
needed the ca_put_callback.  Considering the complication of beamline
applications,  it is better to  port  recDynLink.c  and swait.c to R3.14.
Many Thanks,
Kate
Re: recDynLink.c for R3.14.1 ? Benjamin Franksen
RE: recDynLink.c for R3.14.1 ? Feng, Shuchen
Re: recDynLink.c for R3.14.1 ? Tim Mooney
Prev: Re: NI1014 GPIB controller Marty Kraimer
Next: Re: NI1014 GPIB controller Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: recDynLink.c for R3.14.1 ? Tim Mooney
Next: Re: recDynLink.c for R3.14.1 ? Benjamin Franksen
