1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: NI1014 GPIB controller
To: Marty Kraimer <[email protected]>
Cc: Mark Rivers <[email protected]>, [email protected]
Date: Tue, 15 Apr 2003 08:51:15 -0700
Marty Kraimer wrote:
Mark Rivers wrote:
Marty wrote:
If programed transfers are used instead of DMA there are two big advantages.
1) A24 DMA is no longer required. Thus it will no longer be necessary
to modify the board support packages in order to support the NI1014.
I'm not quite sure I understand what you mean by this. Are you suggesting eliminating support for A24 DMA entirely in the BSP, or just for some quirk of the NI1014? We use the Kinetic Systems 2917 VME/CAMAC adapter, which uses A24 DMA. We definitely need to be able to continue to use these, there are a dozen or more in use on beamlines where they control a critical CAMAC device for multi-element fluorescence detectors. Mark Rivers
Thanks for the info. My interest is the NI1014. I don't see much reason for it to use DMA.
Sorry for putting in my 2 cents:
I don't know anything about the NI1014 or the CPU you are using
nor the amount of data you want to transfer.
But: using DMA for data transfer from/to VME into/out of memory
is almost always a good idea on modern CPUs. PIO on such a slow
bus can stall a fast CPU for a lot of cycles.
-- Till
Marty Kraimer
RE: NI1014 GPIB controller Mark Rivers
Re: NI1014 GPIB controller Marty Kraimer
Prev: Re: recDynLink.c for R3.14.1 ? Kate Feng
Next: Re: recDynLink.c for R3.14.1 ? Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: NI1014 GPIB controller Marty Kraimer
Next: recDynLink.c for R3.14.1 ? Kate Feng
