1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: recDynLink.c for R3.14.1 ?
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Wed, 16 Apr 2003 06:12:05 -0500
Benjamin Franksen wrote:
Hi Marty (and all),
one important limitation (at least in 3.13.x) is missing in appDevGuide:
dbNotifyCancel must not be called from interrupt context.
I did and very bad things happened. BTW, i wonder what will happen if
such a record (i.e. one with asynch soft support) is processed as a
result of a ca_put_calback. Hmmm...
Ben
VERY few things can be called from interrupt context.
The Application Developer's Guide says if a routine can get called from interrupt routines. If it does not say this it should be assumed that the routine can't be called from interrupt context.
Note that the following can be called from interrupt level
callbackRequest
callbackRequestProcessCallback
scanIorequest
One of these should be all you need. For example callbackRequest can cause a user supplied routine to be called by a general purpose callback thread.
Marty Kraimer
Re: recDynLink.c for R3.14.1 ? Benjamin Franksen
RE: recDynLink.c for R3.14.1 ? Feng, Shuchen
Re: recDynLink.c for R3.14.1 ? Tim Mooney
Re: recDynLink.c for R3.14.1 ? Kate Feng
Re: recDynLink.c for R3.14.1 ? Marty Kraimer
Prev: Re: recDynLink.c for R3.14.1 ? Benjamin Franksen
Next: db_parse returned -1 M.C.Shao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: recDynLink.c for R3.14.1 ? Benjamin Franksen
