1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building 3.14.1 under cygwin environment
To: Eric Norum <[email protected]>
Cc: [email protected]
Date: Mon, 28 Apr 2003 12:24:42 +0100
Eric Norum wrote:
> What I usually do in situations like this is to issue the compile
> command with -c changed to -E so I can see exactly what's getting passed
>   on from the preprocessor to the compiler.  The offending line is:
>      fd_set fdSets[fdrNEnums];
> This makes me think that the likely cause of the problem is that
> 1) fd_set is not typefed properly.  (to check, run the output of the
> '-E' compile through 'grep fd_set'.
> OR
> 2) fdSets is being defined as a preprocessor macro somewhere in some
> cygwin header file.  About the only thing to do here is to 'grep fdSets'
> on all the header files.
> BTW -- is EPICS likely to work on win98???
  Thanks for the tips I'll give that a try. Does anyone know the answer
to Eric's question about win98 ? This is my first foray into running
Epics/Channel Access from a Windows environment so any help would be
appreciated. Also, does anyone know what the situation is with XP ?
      Chris Mayer
_______________________________________________________________________
Observatory Sciences Ltd.          Email: [email protected]
William James House                Tel: 44 - (0)1223 - 508257
Cowley Road,                       Fax: 44 - (0)1223 - 508258
Cambridge, CB4 0WX, UK             http://www.observatorysciences.co.uk
RE: Building 3.14.1 under cygwin environment Jeff Hill
Building 3.14.1 under cygwin environment Chris Mayer
Re: Building 3.14.1 under cygwin environment Eric Norum
Prev: Re: Building 3.14.1 under cygwin environment Eric Norum
Next: RE: Building 3.14.1 under cygwin environment Redman, Russell O.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Building 3.14.1 under cygwin environment Jeff Hill
