1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: How to initialize waveform record
To: "'Rod'" <[email protected]>, EPICS Tech Talk <[email protected]>
Cc: "Silva, James" <[email protected]>
Date: Fri, 09 May 2003 16:50:14 -0700
We at SLAC restore waveforms at IOC boot time.  We've modified fdbrestore.c to use ca_array_put.
The source can be found here http://www.slac.stanford.edu/comp/unix/package/epics/extensions/ChannelWatcher/
Mike
-----Original Message-----
Sent: Friday, May 09, 2003 3:05 PM
To: EPICS Tech Talk
Subject: How to initialize waveform record
Greetings.
I have an application which wants to use a waveform record as
a lookup table.  The initial values of the record would need to
be written once at IOC boot time.  It would be suitable to use
something like 'dbpf' in the startup script, but I can't seem
to find a syntax that writes to array elements greater than
index 1.  From a Solaris host, I can do
caput MY:ARRAY:RECORD 123 456 789
and all the values get written.  Any comparable method using
the vxWorks shell?  Or, better still, if I could supply a set
of default values at record initialization.
	---   rod.
 Rod Nussbaumer, Programmer/Technologist    E-mail: [email protected]
 TRIUMF --- University of British Columbia,  Phone: (604)222-7449
 Vancouver, BC, Canada.                        FAX: (604)222-7307
Prev: How to initialize waveform record Rod
Next: Channel Archiver Display Tools Owens, PH (Peter)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
