1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: R3.14.2 & excas
To: "Billy R. Adams" <[email protected]>
Cc: [email protected]
Date: Wed, 28 May 2003 13:58:50 -0500
In <top>/src/excas make the following change
diff -r1.1 Makefile
17c17
< SRC_DIRS += $(TOP)/templates/makeBaseApp/top/caServerApp
> SRC_DIRS += $(INSTALL_TEMPLATES)/makeBaseApp/top/caServerApp
Does this work?
Marty Kraimer
Billy R. Adams wrote:
     "excas" does not compile/install if installing R3.14.2 in
other than the source (default) directory.
If, during the first compile, I change INSTALL_LOCATION in
base-3.14.2/configure/RELEASE.linux-x86 from the default
#INSTALL_LOCATION=<fullpathname>
to
INSTALL_LOCATION=/usr/local/epics-3.14.2
I get the following errors near the completion of compiling epics:
gmake[3]: Entering directory `/home0/bra/EPICS/src/R3.14.2/base-3.14.2/src/excas/O.linux-x86'
gmake[3]: Leaving directory `/home0/bra/EPICS/src/R3.14.2/base-3.14.2/src/excas/O.linux-x86'
gmake[3]: *** No rule to make target `main.o', needed by `excas'. Stop.
gmake[2]: *** [install.linux-x86] Error 2
gmake[2]: Leaving directory `/home0/bra/EPICS/src/R3.14.2/base-3.14.2/src/excas'
gmake[1]: *** [excas.install] Error 2
gmake[1]: Leaving directory `/home0/bra/EPICS/src/R3.14.2/base-3.14.2/src'
gmake: *** [src.install] Error 2
=============================================================== However, if I first compile R3.14.2, and leave the default "#INSTALL_LOCATION=<fullpathname>" set, I do not get these errors. Now after compiling this way, I can change to: "INSTALL_LOCATION=/usr/local/epics-3.14.2" and I do not get the compile errors. "R3.14.2/base/bin/linux-x86/excas" is installed, but "/usr/local/epics-3.14.2/bin/linux-x86/excas" is not installed. I manually copy excess to "/usr/local/epics/bin/linux-x86/excas"
     I am using Redhat Linux 7.3 and 8.0 on an i686.  Other
configuration files were modified from working epics-3.14.1 files
Questions:
1.  Does my way of getting excas compiled and moved give the desired
    results?
2.  What modifications would allow "excas" to compile and install
    correctly the first time when not installing in the default
    directory?
Billy Adams    <mailto:[email protected]>
                Raytheon Technical Services
  Assigned to:  Research Facilities Branch of
                Research Facilities Management Office
  16 Victory Street Mail Stop 413
  Building 1251, Room 126D
  NASA Langley Research Center
  Hampton, Va. 23681-2199
  Phone 1-757-864-6242     Fax   1-757-864-8095
Re: R3.14.2 & excas Billy R. Adams
Prev: Building epics3.14.2 under windows Chris Mayer
Next: Re: R3.14.2 & excas Billy R. Adams
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: R3.14.2 & excas Billy R. Adams
