1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building EPICS R3.14.2 under Windows
To: Renata Krempaska <[email protected]>
Cc: [email protected], tech-talk <[email protected]>
Date: Fri, 20 Jun 2003 07:56:20 -0400
I simply commented out the softIoc build and everything else built fine.
So, I now have Libraries for WIN32 as well.  I justed wanted to know why
the <>/src/softIoc directory does not build.  Well, I will look into it
later. (Hopefully, it is something simple)
Ernest L. Williams Jr.
SNS Control Systems Group
ORNL
On Fri, 2003-06-20 at 03:41, Renata Krempaska wrote:
> Ernest L. Williams Jr. wrote:
> > HI,
> > I saw your tech-talk message about the softIoc section not building under
> > R3.14.2 on Windows.
> > Did anyone ever respond with an answer.  I am having the same problem.
> Yes, I had answer from Mark Rivers, he sent me the libraries and it
> works fine.
> works fine. We could easily do epics PVs get and put from VB. This
> solved our problem to integrate a comertial product, ImagePro with EPICS.
> Just one remark: We are using Epics3.13.x.
> Renata.
Building EPICS R3.14.2 under Windows Ernest L. Williams Jr.
Re: Building EPICS R3.14.2 under Windows Renata Krempaska
Prev: Re: Building EPICS R3.14.2 under Windows Renata Krempaska
Next: Maximum (Minimum) Value of a Set of Readback PVs John K Munro Jr
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
