1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Maximum (Minimum) Vaue of a Set of Readback PVs
To: tech-talk <[email protected]>
Date: Tue, 24 Jun 2003 21:19:15 +0200
Sorry, that was indeed the outpur of the script. If I've improoved my mail skills yet, the script should be attached now
-- [email protected] ----------- Bessy Gmbh -----------------
-- +49 30 6392 4981 ------------------ Albert Einstein Strasse 15 -
-------------------------------------- 12489 Berlin ---------------
eval 'exec perl -S $0 ${1+"$@"}'  # -*- Mode: perl -*-
	if $running_under_some_shell;
use strict;
# $Log$
# CreateSt.pl
# A little helper to create a snl program that watches a set of PV's and sets a
# bo record to 1 if at least one of the watched PVS is 1 and set's it to 0 if all
# PV's are 0. Needed to create a summ signal for many error conditions.
# For every state set with the functionality described above define a list of
# Variables to be monitored. Declare all of this lists in %allSig the rest is done
# by the script. It is made shure that PV's that are needed in multiple lists are
# declared and monitored only once.
# The subroutine 'stateSet' defines what to do in the state set. It can be modified
# easily.
###########   define dependencies here  ##########
### define a list for every state set.
my $applicationName='PPTMOD';
my @misc = qw(PPTMOD:CabDoorSw PPTMOD:EarthSw PPTMOD:EmergSw
		PPTMOD:eoLineMax PPTMOD:GndRod
my @cooling = qw(PPTMOD:BodyWaFlSw PPTMOD:CavyWaFlSw PPTMOD:CircWaFlSw
		PPTMOD:CollWaFlSw PPTMOD:LoadWaFlSw PPTMOD:MagnetTempSw
		PPTMOD:MagnWaFlSw PPTMOD:TankTempSw PPTMOD:TankWaFlSw
### Create one state set for every list
my %allSig = ("misc" => \@misc,
              "cooling" => \@cooling,
##########   from now on: DON'T EDIT   ##########
  print "**** Creating: state machine for $applicationName application ****\n";
# Create a hash with all signals once
  my %allSignals;
  my $nrOfSignals=0;
  foreach my $s (keys(%allSig))
    my $rSig = $allSig{$s};
    my %Sig;
    foreach my $sig (@$rSig)
    { my $idx = $allSignals{$sig};
      next if( defined $idx );
      $idx = $nrOfSignals;
      $nrOfSignals++;
      $allSignals{$sig}=$idx;
#  print "All signals and indices, $nrOfSignals\n";
#  my $idx=0;
#  my %revSig = reverse %allSignals;
#  foreach my $pv (sort keys %allSignals){ printf ("%30s = %2d    %2d = %s\n",$pv,$allSignals{$pv},$idx,$revSig{$idx}); $idx++;}
  open (ST, ">$applicationName.st") or die "Can't open file: $applicationName.st: $!";
# Create header of .st file declare and monitor all PV's
  print ST   "program $applicationName\n".
	     "\n".
	     "int stt[$nrOfSignals];\n";
# Define one record for each state set for the output of the calculation done in the state set
  print "\tcreate: $applicationName.st ($nrOfSignals signals). Need epics bo-records:\n";
  foreach my $s (keys(%allSig) )
  { print ST "int $s"."On;\n"; # nameOfTheListOn
    print "\t- $s"."On,\n";
  print ST "\n";
  foreach my $s (keys %allSig )
  { print ST "assign $s"."On \tto \"$applicationName:$s"."On\";\n";
  print ST   "\n/*sorted in alphabetical order of signals*/\n";
  my $idx=0;
  foreach my $sig (sort keys %allSignals)
  { print ST "assign stt[$allSignals{$sig}] to \t\"$sig\";\n";
    #print  "$sig assign stt[$idx] to \t\"$revSig{$sig}\";\n";
    $idx++;
  print ST   "\n".
	     "monitor stt;\n".
	     "\n";
# now all PVs are declared so create a state set for every list
  foreach my$sig (keys %allSig)
  { stateSet($sig, $allSig{$sig});
  # Close output file
  close ST or die "Can't close output file: $applicationName"."psOff.st $!\n";
# Create this state set for one list
sub stateSet
{ my($name,$rPVs) = @_;		# name of the state set and PV's related to it
  my $nRows = scalar(@$rPVs);	# number of PV's
# init state
  print ST   "ss $name"."States\n".
             "{\n".
             "  state st_$name"."Init\n".
             "  { when()\n".
             "    { $name"."On=1;\n".
             "      pvPut($name"."On);\n".
             "    } state st_$name"."On\n".
             "  } \n".
             "\n".
             "  state st_$name"."Off\n".
             "  { when(stt[$allSignals{$rPVs->[0]}]";
# the 'one is on' state
  for( $idx=1; $idx<$nRows; $idx++)
  { print ST "||stt[$allSignals{$rPVs->[$idx]}]";
  print ST   ")\n".
             "    { $name"."On = TRUE;\n".
             "  }\n".
             "\n".
# the 'all are off' state
             "  state st_$name"."On\n".
             "  { when(!stt[$allSignals{$rPVs->[0]}]";
  { print ST "&&!stt[$allSignals{$rPVs->[$idx]}]";
  print ST   ")\n".
             "    { $name"."On = FALSE;\n".
             "    } state st_$name"."Off\n".
             "  }\n".
             "}\n\n";
  close ST or die "Can't close output file: $!\n";
Re: Maximum (Minimum) Vaue of a Set of Readback PVs kuner
Prev: Setting TZ for RTEMS so that local time is correct Allison, Stephanie
Next: Segmentation faults and the ioc example Geoff Savage
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Maximum (Minimum) Vaue of a Set of Readback PVs kuner
Next: Setting TZ for RTEMS so that local time is correct Allison, Stephanie
