1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Maximum (Minimum) Vaue of a Set of Readback PVs
To: tech-talk <[email protected]>
Date: Tue, 24 Jun 2003 19:44:17 +0200
If you want to create a state set as Tim Mooney suggested (I would prefer this solution) May be this script for a automatic snl-file generation could be helpful. You can run it to understand what happens, but it has to be adapted to your requirements.
regards
Bernhard Kuner
-- [email protected] ------- Bessy Gmbh -----------------
-- +49 30 6392 4981 -------------- Albert Einstein Strasse 15 -
---------------------------------- 12489 Berlin ---------------
program PPTMOD
int stt[14];
int miscOn;
int coolingOn;
assign miscOn 	to "PPTMOD:miscOn";
assign coolingOn 	to "PPTMOD:coolingOn";
/*sorted in alphabetical order of signals*/
assign stt[5] to 	"PPTMOD:BodyWaFlSw";
assign stt[0] to 	"PPTMOD:CabDoorSw";
assign stt[6] to 	"PPTMOD:CavyWaFlSw";
assign stt[7] to 	"PPTMOD:CircWaFlSw";
assign stt[8] to 	"PPTMOD:CollWaFlSw";
assign stt[1] to 	"PPTMOD:EarthSw";
assign stt[2] to 	"PPTMOD:EmergSw";
assign stt[4] to 	"PPTMOD:GndRod";
assign stt[9] to 	"PPTMOD:LoadWaFlSw";
assign stt[11] to 	"PPTMOD:MagnWaFlSw";
assign stt[10] to 	"PPTMOD:MagnetTempSw";
assign stt[12] to 	"PPTMOD:TankTempSw";
assign stt[13] to 	"PPTMOD:TankWaFlSw";
assign stt[3] to 	"PPTMOD:eoLineMax";
monitor stt;
ss miscStates
  state st_miscInit
  { when()
    { miscOn=1;
      pvPut(miscOn);
    } state st_miscOn
  state st_miscOff
  { when(stt[0]||stt[1]||stt[2]||stt[3]||stt[4])
    { miscOn = TRUE;
      pvPut(miscOn);
    } state st_miscOn
  state st_miscOn
  { when(!stt[0]&&!stt[1]&&!stt[2]&&!stt[3]&&!stt[4])
    { miscOn = FALSE;
      pvPut(miscOn);
    } state st_miscOff
ss coolingStates
  state st_coolingInit
  { when()
    { coolingOn=1;
      pvPut(coolingOn);
    } state st_coolingOn
  state st_coolingOff
  { when(stt[5]||stt[6]||stt[7]||stt[8]||stt[9]||stt[10]||stt[11]||stt[12]||stt[13])
    { coolingOn = TRUE;
      pvPut(coolingOn);
  state st_coolingOn
  { when(!stt[5]&&!stt[6]&&!stt[7]&&!stt[8]&&!stt[9]&&!stt[10]&&!stt[11]&&!stt[12]&&!stt[13])
    { coolingOn = FALSE;
      pvPut(coolingOn);
    } state st_coolingOff
Prev: Re: Maximum (Minimum) Value of a Set of Readback PVs kuner
Next: Setting TZ for RTEMS so that local time is correct Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Waveform calaulation for each element Singleton, SJ (Steve)
Next: Re: Maximum (Minimum) Vaue of a Set of Readback PVs kuner
