1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Waveform calaulation for each element
To: "'DING JIANGUO'" <[email protected]>, [email protected]
Date: Tue, 24 Jun 2003 09:59:24 +0100
Hello,
I implemented a simple sub record to read a series of individual values from different ai records and write them into the elements of a waveform record, the code for which is attached.  It should be straightforward to use the same method to read elements from one waveform, perform your calculation and write the calculated values to another.  Please note that the attached code uses INPA as the address of the output waveform record.
Hope this helps.
Steve Singleton
-----Original Message-----
Sent: 24 June 2003 09:24
To: [email protected]
Cc: [email protected]
Subject: Waveform calaulation for each element
hi, all
Has anyone implemented array processing with a
subroutine record?
I want to access the values in a waveform (WFM) record with a
subroutine record, cacultate for each element and pass the array to the output.
        WFM  -->|a   out|---->  WFM
        ai   -->|b      |
        ai   -->|c      |   for idx=0..499
                |       |       (a[idx] - b ) * c
                | SUB-  |
                | ROUT- |
                | INE   |
Jianguo DING
SSRF, Shanghai Institute of Nuclear Research
Chinese Academy of Science
Attachment: pressArray.c
Description: Binary data
Prev: Waveform calaulation for each element DING JIANGUO
Next: Re: Waveform calaulation for each element Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Waveform calaulation for each element Alexei Dmitrovski
Next: Re: Maximum (Minimum) Vaue of a Set of Readback PVs kuner
