1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem with static build on Linux
To: <[email protected]>
Date: Thu, 31 Jul 2003 19:44:47 -0500
Folks,
I have now reproduced the problem with static builds on Linux (Redhat 8)
even with the simple exampleApp that is distributed with EPICS base
(3.14.2).
I added the following line to exampleApp/configure/CONFIG
STATIC_BUILD=YES
and rebuilt exampleApp.
When I run the application I get the following:
millenia> ../../bin/linux-x86/myexample st.cmd
dbLoadDatabase("../../dbd/myexample.dbd",0,0)
registerRecordDeviceDriver(pdbbase)
dbLoadRecords("../../db/dbExample1.db","user=epicsHost")
dbLoadRecords("../../db/dbExample2.db","user=epicsHost,no=1,scan=1
second")
dbLoadRecords("../../db/dbExample2.db","user=epicsHost,no=2,scan=2
second")
dbLoadRecords("../../db/dbExample2.db","user=epicsHost,no=3,scan=5
second")
dbLoadRecords("../../db/dbSubExample.db","user=epicsHost")
iocInit()
Starting iocInit
Starting iocInit
###  EPICS IOC CORE built on May 22 2003
###  EPICS R3.14.2 $R3-14-2$ $2003/03/18 22:44:29$
Record epicsHost:subExample called mySubInit(0x8289f48, 0x8063500)
Segmentation fault
I then ran the debugger on the resulting core file.
millenia> gdb ../../bin/linux-x86/myexample core.7772
Core was generated by `../../bin/linux-x86/myexample st.cmd'.
Program terminated with signal 11, Segmentation fault.
#0  0x08184f04 in nss_getline ()
(gdb) backtrace
#1  0x08184749 in nss_parse_file ()
#2  0x08184374 in __nss_database_lookup ()
#3  0x0818564a in __nss_passwd_lookup ()
#4  0x0818085f in getpwuid_r ()
#5  0x081803dc in getpwuid ()
#6  0x080e0b15 in osiGetUserName ()
#7  0x080b3dc6 in cac::cac(cacNotify&) ()
#8  0x080ae432 in ca_client_context::ca_client_context(bool) ()
#9  0x080a686e in ca_context_create ()
#10 0x080912c3 in dbCaTask ()
#11 0x080dfaf1 in start_routine ()
#12 0x080e81a9 in pthread_start_thread ()
This has now been reproduced on 3 separate Redhat 8 machines.  Andrew
Johnson built on a Redhat 9 machine, and the resulting static binary
worked when run under both Redhat 9 and Redhat 8.  It would be great if
some other folks could try this on Redhat 8 and 9 and see if it is
actually a version problem.  Any ideas why it does not work on Redhat 8
would be most welcome.
Mark Rivers
Re: Problem with static build on Linux Andrew Johnson
Prev: edb.def Bill Cruise
Next: Re: edb.def Andy Foster
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: OMS motor card JOG mode problems Ronald L. Sluiter
Next: Re: Problem with static build on Linux Andrew Johnson
