1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem with static build on Linux
To: "Andrew Johnson" <[email protected]>
Cc: <[email protected]>
Date: Fri, 1 Aug 2003 11:40:43 -0500
Andrew,
Thanks for taking the time to track this down.
> I've filed a bug report to request the ability to build mixed-mode
> binaries using this linker feature, but I don't know whether
> Janet would be able to implement it in time for R3.14.3, probably
not...
I think this would be generally desireable, not just as a workaround for
the problem with Redhat 8.  It seems like a good idea to link
dynamically with the things that should be installed on every Linux
system, and statically with the thing from EPICS.
Prev: RE: Problem with static build on Linux John Quintana
Next: multiple identical names from casr 2 Geoff Savage
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem with static build on Linux D. Peter Siddons
Next: Re: Problem with static build on Linux Robert Soliday
