1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with static build on Linux
To: John Quintana <[email protected]>
Cc: "'Andrew Johnson'" <[email protected]>, "'Mark Rivers'" <[email protected]>, [email protected]
Date: Fri, 01 Aug 2003 15:19:38 +0200
I remember that RH8 used a 'non-standard' gcc (2.96?) which was never an official Gnu release, and which was quite broken. I don't remember if they (RH) ever replaced it before RH9. There are reams of email complaints in the various lists.
Pete.
John Quintana wrote:
This wouldn't be the first time that glibc incompatabilites have come
up.
I've heard that the linux bbc distribution that normally compiles fine
under
Debian chokes miserably under Redhat 8.0.
- John
John Quintana                                  630-252-0221  (ph.)
Northwestern University                   630-252-0226  (fax)
Building 432/A001                           [email protected]
9700 S. Cass Ave
Argonne IL 60439
-----Original Message-----
From: Andrew Johnson [mailto:[email protected]] Sent: Friday, August 01, 2003 11:31 AM
To: Mark Rivers
Cc: [email protected]
Mark Rivers wrote:
This has now been reproduced on 3 separate Redhat 8 machines.  Andrew
Johnson built on a Redhat 9 machine, and the resulting static binary
worked when run under both Redhat 9 and Redhat 8.  It would be great
if
some other folks could try this on Redhat 8 and 9 and see if it is
actually a version problem.  Any ideas why it does not work on Redhat
8
would be most welcome.
Mark,
I'm now convinced this is a glibc problem - I rebuilt base on RH 8.0,
and confirmed that I can reporduce your problem with a static build of the example application. Then I rebuilt the example app on my RH 9.0
machine but using the 8.0 build of base (this way around works, the reverse doesn't). The only difference between the code in the result is the OS libraries, which on RH 9.0 means glibc 2.3.2 vs 2.2.93. This binary
runs quite happily on both OS versions.
I also managed to manually build a working executable on RH8.0 that statically linked to the libraries from base but dynamically to the
system libraries. The command line I used was this:
/usr/bin/g++ -o example -L/home/phoebus/ANJ/epics/base/3-14-dev/lib/linux-x86/ -L/home/phoebus3/ANJ/apps/example-3.14/lib/linux-x86/ example_registerRecordDeviceDriver.o dbSubExample.o exampleMain.o -Wl,-Bstatic -lxxxSupport -lrecIoc -lsoftDevIoc -ltestDevIoc -liocsh -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -Wl,-Bdynamic -lpthread -lreadline -lncurses
-lm -lrt
Note the strategically placed -Wl,Bstatic and -Wl,-Bdynamic arguments.
I've filed a bug report to request the ability to build mixed-mode binaries using this linker feature, but I don't know whether Janet would
be able to implement it in time for R3.14.3, probably not...
- Andrew
D. Peter Siddons
Bldg. 725D, NSLS
Brookhaven National Laboratory
Upton, NY 11976
USA.
Email: [email protected]
RE: Problem with static build on Linux John Quintana
Prev: Re: edb.def Andy Foster
Next: Re: Problem with static build on Linux Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Problem with static build on Linux John Quintana
Next: RE: Problem with static build on Linux Mark Rivers
