1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem with static build on Linux solved
To: "tech-talk" <[email protected]>
Date: Fri, 1 Aug 2003 14:26:52 -0500
Following up on suggestions here earlier today I upgraded all of the
glibc packages on my Redhat 8 machine to the latest versions from
Redhat.  It does indeed fix the problem, and I can now build
applications statically that run fine.
sonata> rpm -qa | grep glibc
glibc-debug-2.3.2-4.80.6
glibc-2.3.2-4.80.6
glibc-devel-2.3.2-4.80.6
glibc-common-2.3.2-4.80.6
glibc-profile-2.3.2-4.80.6
glibc-kernheaders-2.4-7.20
glibc-utils-2.3.2-4.80.6
glibc-debug-static-2.3.2-4.80.6
Thanks for all the help.
Mark Rivers
Prev: Re: Problem with static build on Linux Robert Soliday
Next: RE: multiple identical names from casr 2 Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: dynamically remove PV's from excas? Jeff Hill
Next: about building caTCL zhaozhuo
