1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: multiple identical names from casr 2
To: "'Geoff Savage'" <[email protected]>, <[email protected]>
Date: Mon, 4 Aug 2003 11:44:14 -0600
> When looking at the channel access client information on IOCs running
> EPICS R3.13.4 we usually see the same name listed multiple times.
> Here is an example.
> Client Name="bartlett", Client Host="d0ol20.fnal.gov", V4.8, Channel
> Count=6
>          TId=0X171E54, Protocol=TCP, Socket FD=11
>          Secs since last send   1.63, Secs since last receive   1.63
>          Unprocessed request bytes=0, Undelivered response bytes=0
>          Client's DNS Host Name d0ol20:55513 State=up
>          33358 bytes allocated
>          MUO_PROC_23/FD(0r-)     MUO_PROC_23/FD(0rw)
> MUO_PROC_23/MEM(0r-)
>          MUO_PROC_23/MEM(0rw)    MUO_PROC_23/CPU(0r-)
> MUO_PROC_23/CPU(0rw)
This indicates that your client side application has created multiple channels
for the same PV name.
> Does this indicate a problem with our channel access client?
This certainly indicates that there is room for optimization. Whether this is
necessary or not will depend on your situation - how many channels, how often
this gets used etc.
> What is the key for the code following the record names?
This is documented in the ADG.
The entries all take this form.
pvName(nnnn{r,-}{w,-})
Where the nnnn indicates the number of monitor subscriptions attached to the
channel. The {r,-} indicates whether there is or isn't read access. The {w,-}
indicates whether there is or isn't write access. Sorry about the cryptic code,
but compactness seemed to be appropriate when printing a list of channels (which
could be long).
Jeff
--- Begin Message ---
Subject: multiple identical names from casr 2
To: <[email protected]>
Date: Fri, 1 Aug 2003 11:03:25 -0600
Title: multiple identical names from casr 2
EPICS R3.13.4 we usually see the same name listed multiple times.  Here
is an example.
Client Name="bartlett", Client Host="d0ol20.fnal.gov", V4.8, Channel Count=6
Does this indicate a problem with our channel access client?  What is
Thanks
Geoff
--- End Message ---
multiple identical names from casr 2 Geoff Savage
Prev: Problem with static build on Linux solved Mark Rivers
Next: RE: dynamically remove PV's from excas? Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: multiple identical names from casr 2 Geoff Savage
Next: puzzling "Record Type does not exist" message Michael Borland
