1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Does DISP work for DB OUT links? Related question
To: [email protected]
Date: Thu, 28 Aug 2003 11:14:56 +0200
> >>>I mean, if DISP=TRUE, does this also disable setting fields via db (out)
> >>>links?
> >>dbPutField and dbPutNotify requests are disabled.
> >>This it only disables Channel Access puts.
> >>Database links are NOT disabled.
> >>Channel Access client puts (this includes CA links) are disabled.
> > Is there any way to disable *all* puts to a record?
> No.
Marty,
thanx for your answers. I just asked myself what happens when the record
is being processed (scan lock active). Then remembered that records with
out links are *always* in the same lockset with the target record (even
if NPP NMS), so this will prevent the record that is being processed
from outside field changes.
Next question: If the record is being processed asynchronously, i.e.
PACT=TRUE but scan lock is not active (record is waiting for the
prcosess callback). Then the fields are not protected from changes via
other records' output links, correct? I.e. one cannot rely on such a
record's fields having the same values as when the callback was set up
during the first call to process?
Ben
Re: Does DISP work for DB OUT links? Related question Marty Kraimer
Does DISP work for DB OUT links? Benjamin Franksen
Re: Does DISP work for DB OUT links? Marty Kraimer
Re: Does DISP work for DB OUT links? Benjamin Franksen
Prev: Re: Does DISP work for DB OUT links? Marty Kraimer
Next: Re: Does DISP work for DB OUT links? Related question Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
