1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Does DISP work for DB OUT links? Related question
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Thu, 28 Aug 2003 07:35:14 -0500
I mean, if DISP=TRUE, does this also disable setting fields via db (out)
links?
dbPutField and dbPutNotify requests are disabled.
This it only disables Channel Access puts.
Database links are NOT disabled.
Channel Access client puts (this includes CA links) are disabled.
Is there any way to disable *all* puts to a record?
No.
Marty,
thanx for your answers. I just asked myself what happens when the record
is being processed (scan lock active). Then remembered that records with
out links are *always* in the same lockset with the target record (even
if NPP NMS), so this will prevent the record that is being processed
from outside field changes.
Next question: If the record is being processed asynchronously, i.e.
PACT=TRUE but scan lock is not active (record is waiting for the
prcosess callback). Then the fields are not protected from changes via
other records' output links, correct? I.e. one cannot rely on such a
record's fields having the same values as when the callback was set up
during the first call to process?
You are correct. This is a really nasty side effect of asynchronous processing.
The following assumes a passive record.
If a value is written to a record between the two phases of record processing the following is done.
The value is written to the record. If the field has pp(TRUE), i.e. process passive, the record will be processed again when the record completes asynchronous processing.
Thus can lead to strange side effects.
Kay Kasemir and Jeff Hill just told me of one.
Assume a bo record has the value 0.
Two puts are sent to the record. The first is 1 and the second is 0.
If the first asynchronous completion occurs before the second put everything works just like for synchronous records. Two channel access monitors will be issued. The first returns 1. The second returns 0.
If the second put occurs before the asynchronous completion from the first, NO ca monitors are issued. The explaination is as follows:
The put of 1 occurs:
    1 is written to the VAL field
    The record starts synchronous processsing
The put of 0 occurs
    0 is written to the record
    A flag is set requesting that the record be reprocessed
The asynchronous completion because of the first put occurs.
    Record support compares MLST and VAL.
    Since they are the same because of the second put, no monitor occurs.
The record is processed again
    The record starts asynchronous processing
The asynchrononous completion occurs.
    MLST and VAL are both still 0. Thus no monitors.
Thus asynchronous records can lead to strange behavior.
See the 3.14 Application Developer's Guide
    Chaper: Database Locking, Scanning, and Processing
    Section Guidelines for Asynchronous Records
    Section: Cached Puts
    Section putNotify
I see no easy solution and perhaps no solution without significent runtime overhead.
Marty Kraimer
Changes to records during asynch processing Benjamin Franksen
Does DISP work for DB OUT links? Benjamin Franksen
Re: Does DISP work for DB OUT links? Marty Kraimer
Re: Does DISP work for DB OUT links? Benjamin Franksen
Re: Does DISP work for DB OUT links? Related question Benjamin Franksen
Prev: Re: Does DISP work for DB OUT links? Related question Benjamin Franksen
Next: autoSaveRestore_R3.13.5_R3.3 Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Changes to records during asynch processing Benjamin Franksen
