1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Home signal does not affect the .ATHM field of the motor record
To: [email protected]
Date: Tue, 02 Sep 2003 09:25:52 +0200
Hello everyone!
I'm having a peculiar problem here. I have a home switch which is 0 on one side of home and 1 on the other. When I move across the switch, I can see the change in the .MSTA field of the record, but only bit 4 changes and not bit 8. The .ATHM is unaffected as well.
I'm using motor record version 4.2
Any ideas?
Cheers
Rok
Prev: Re: about NFS Billy R. Adams
Next: Re: Changes to records during asynch processing Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: [Fwd: Re: Does DISP work for DB OUT links? Related question] Owens, PH (Peter)
Next: building medm on RH9/RH Motif Arne P. Freyberger
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
