1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epics ioc3.14.3 problem at the tornado2.2
To: Kiman Ha <[email protected]>
Cc: [email protected]
Date: Fri, 12 Sep 2003 14:10:51 -0500
Kiman Ha wrote:
But base3.14.2 and base3.14.3 versions
test_registerRecordDeviceDriver(pdbbase) functions loding errors.
Were there any error messages from [gnu]make when you built this application?
alignment
Exception current instruction address: 0x00000020
Machine Status Register: 0x0200b030
Data Access Register: 0x073b509b
Condition Register: 0x20002044
Data storage interrupt Register: 0x00005fff
24aa24 vxTaskEntry    +68 : shell ()
2017ec shell          +190: 201818 ()
201a18 shell          +3bc: execute ()
201b54 execute        +90 : 201818 ()
201b9c execute        +d8 : yyparse ()
21fd10 yyparse        +71c: 21e0a8 ()
21e22c yystart        +96c: test_registerRecordDeviceDriver ()
72b0e34 test_registerRecordDeviceDriver+12c: 20 ()
The above stack trace shows that the processor is trying to execute instructions from address 0x20, which cannot be the correct address for the sizeOffset routine of any record type. This is probably an unresolved reference.
The probeem from this functions. sizeOffset(dbEntry.precordType);
You should try doing a "make rebuild" (or "gnumake rebuild") from the top of your application - I suspect it didn't link properly. If the build fails or prints any warning or error messages you need to investigate and fix those. If that doesn't solve it, did you have any problems building base at all? Was this test application created by R3.14.3, or by a different release of Base?
- Andrew
There are 10 types of people in the world:
Those who understand binary, and those who don't.
epics ioc3.14.3 problem at the tornado2.2 Kiman Ha
Prev: epics ioc3.14.3 problem at the tornado2.2 Kiman Ha
Next: Re: Re: epics ioc3.14.3 problem at the tornado2.2 Kiman Ha
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
