1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Re: epics ioc3.14.3 problem at the tornado2.2
To: "\"AndrewJohnson\"" <[email protected]>
Cc: <[email protected]>
Date: Sat, 13 Sep 2003 06:14:38 +0900
Dear Andrew,
Thanks for your prompt reply for my problem.
> Were there any error messages from [gnu]make when you built this application?
The base and application compile was just clearly completed. This problem was iocCore loading after record registration problem.
I tried many times recompile and excutions the base3.14.2 and base3.14.3 example IOCs.
At the Windows2K and linux OS  the base3.13.2 with base3.13.3 working well for my applications.
> You should try doing a "make rebuild" (or "gnumake rebuild") from the top
> of your application - I suspect it didn't link properly.  If the build
> fails or prints any warning or error messages you need to investigate and
> fix those.  If that doesn't solve it, did you have any problems building
> base at all?
The base program and any application compiles clean without error message.
But the same target environment the base3.14.1.cvs version was woking well.
>Was this test application created by R3.14.3, or by a
> different release of Base?
I'm sure, application created at the same release.
My Host environment :
-Windows2K
-Tornado2.2 (vxWorks5.5.1)
-used base : base3.13.7, base3.13.8
                    base3.14.1.cvs
Best regards,
Kiman Ha,
PLS Control group
> -----Original message-----
> From: "AndrewJohnson" <[email protected]>
> To: "KimanHa" <[email protected]>
> Cc: [email protected]
> Date: 09/13/2003(Sat)04:10
> Subject: Re: epics ioc3.14.3 problem at the tornado2.2
> Kiman Ha wrote:
> > But base3.14.2 and base3.14.3 versions
> > test_registerRecordDeviceDriver(pdbbase) functions loding errors.
> > alignment
> > Exception current instruction address: 0x00000020
> > Machine Status Register: 0x0200b030
> > Data Access Register: 0x073b509b
> > Condition Register: 0x20002044
> > Data storage interrupt Register: 0x00005fff
> > 24aa24 vxTaskEntry    +68 : shell ()
> > 2017ec shell          +190: 201818 ()
> > 201a18 shell          +3bc: execute ()
> > 201b54 execute        +90 : 201818 ()
> > 201b9c execute        +d8 : yyparse ()
> > 21fd10 yyparse        +71c: 21e0a8 ()
> > 21e22c yystart        +96c: test_registerRecordDeviceDriver ()
> > 72b0e34 test_registerRecordDeviceDriver+12c: 20 ()
> The above stack trace shows that the processor is trying to execute
> instructions from address 0x20, which cannot be the correct address for
> the sizeOffset routine of any record type.  This is probably an unresolved
> reference.
> > The probeem from this functions.  sizeOffset(dbEntry.precordType);
> base at all?  Was this test application created by R3.14.3, or by a
> - Andrew
> There are 10 types of people in the world:
> Those who understand binary, and those who don't.
Prev: Re: epics ioc3.14.3 problem at the tornado2.2 Andrew Johnson
Next: Problems using Epics R3.14.3 with mvme5110 PowerPc Dennis Armstrong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
