1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CA; data length before TCP level
To: "'Liyu, Andrei'" <[email protected]>, <[email protected]>
Date: Wed, 8 Oct 2003 12:41:40 -0600
> 	Where is placed overhead? Before DBR_XXX structure or after N-1
> array?
Just before the payload - the payload includes both the DBR_XXX structure
and the N-1 array.
Jeff
> Andrei.
> -----Original Message-----
> From: Jeff Hill [mailto:[email protected]]
> Sent: Wednesday, October 08, 2003 11:42 AM
> To: Liyu, Andrei; [email protected]
> Hi Andrei,
> The data payload size for an N element array will be the size of the
> DBR_XXX
> type plus N-1 times the size of the value field in the DBR_XXX type. The
> Channel Access overhead for data payloads less than 64k bytes is 16
> bytes.
> The Channel Access overhead for data payloads greater than 64k bytes is
> 24
> bytes.
> Jeff
> > From: Liyu, Andrei [mailto:[email protected]]
> > Sent: Tuesday, October 07, 2003 3:26 PM
> > To: [email protected]
> > Subject: CA; data length before TCP level
> > Hi,
> >        Example.
> >        Client opens CA channel to PV. PV is big array. Client is
> getting
> > data 100, 1000, ... Server does data packet. Data packet consists from
> >       - head of data has timestamps, status, severity and so on
> > 	- array
> > 	- additional data for connection to client computer, to client
> > program, to this channel and so on.
> > We would like to know how we may calculate exact number bytes of data
> > packet before TCP level.
> > Can someone explain data structure for network?
> > Thanks, Andrei.
RE: CA; data length before TCP level Liyu, Andrei
Prev: RE: CA; data length before TCP level Liyu, Andrei
Next: database expansion in R3.14.4 Carl Lionberger
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
