1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Encoders
To: Robert Henning <[email protected]>
Cc: [email protected]
Date: Mon, 20 Oct 2003 17:10:07 -0500
Robert,
If you are running synApps, OMS boards, and the "APS standard" motor
connection hardware, then the easiest way to read your encoder into EPICS
is to use the OMS VME58-4E card.  You also could use something like this
http://www.usdigital.com/products/ad4b/
and read the encoder counts with an EPICS generic serial record.
Kurt Goetze
APS/AOD/Beamline Controls
Robert Henning wrote:
> I am trying to integrate some Renishaw encoders into EPICS and I am
> trying to find a simple solution.  I don't have a lot of experience with
> encoders so any comments or suggestions would be welcome.  At this point
> I only want to use the encoders to verify my stepper motor position and
> I was hoping for a simple RS232 interface.  I know this has been done
> with other brands of encoders but I have not seen anything with the
> Renishaw brand.  The encoders have "Differential signals in quadrature
> to RS422 - output via line drivers".
> I know I could use the OMS58-4 card but I think that is more then I
> need.  I just want to be able to read in the information to EPICS for
> now.
> Thanks in advance,
> Robert Henning
> Operations Manager/Beamline Scientist/User Support Specialist
> University of Chicago at Argonne
> 9700 South Cass Avenue
> BioCARS - Building 434 B
> Argonne, IL 60439
> phone: (630) 252-0446
> fax:   (630) 252-0443
Re: Encoders David Maden
Encoders Robert Henning
Prev: Re: CA block sem corrupted error and S_errno_ENOBUFS Andrew Johnson
Next: Re: Encoders David Maden
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Encoders Robert Henning
